ArcGIS.Core.CIM Namespace / CIMPictureFill Class
    CIMPictureFill Class Properties
    For a list of all members of this type, see CIMPictureFill members.
    Public Properties
     NameDescription
    Public Property Gets or sets the animations that are applied to the symbol layer. (Inherited from ArcGIS.Core.CIM.CIMSymbolLayer)
    Public Property Gets or sets a value indicating whether the color set at the basic properties level is applied to the symbol layer. If the symbol layer is color locked then changes made to the color in the basic properties will not be applied to the symbol layer. (Inherited from ArcGIS.Core.CIM.CIMSymbolLayer)
    Public Property Gets or sets the color substitutions which allows colors in the image to be substituted with a different color.
    Public Property Gets or sets whether the geometric effects that are applied to the symbol layer. Effects dynamically alter the feature geometry when the symbology is applied. Multiple effects applied to a symbol layer are rendered sequentially. (Inherited from ArcGIS.Core.CIM.CIMSymbolLayer)
    Public Property Gets or sets a value indicating whether the symbol layer is visible. The symbol layer draws only when enabled. Currently, an invisible layer is not considered in any transformations when in a 3D context. (Inherited from ArcGIS.Core.CIM.CIMSymbolLayer)
    Public Property Gets or sets the height of the image.
    Public Property Gets or sets the internal name of the symbol layer used for symbol level drawing. (Inherited from ArcGIS.Core.CIM.CIMSymbolLayer)
    Public Property Gets or sets the distance that the image is offset in the horizontal direction.
    Public Property Gets or sets the distance that the image is offset in the vertical direction.
    Public Property Gets or sets a value indicating whether or not the symbol layer should overprint in press printing. (Inherited from ArcGIS.Core.CIM.CIMSymbolLayer)
    Public Property Gets or sets the primitive name. (Inherited from ArcGIS.Core.CIM.CIMSymbolLayer)
    Public Property Gets or sets angle of the image within the fill.
    Public Property Gets or sets the width of the symbol without changing the height (or depth in 3D), as a ratio.
    Public Property Gets or sets how the image is resampled.
    Public Property Gets or sets the color that is applied as a tint to the image. The color is applied to the whole image. When the tint is set to white the image appears with its native colors.
    Public Property Gets or sets the URL of the image. Typically a base64 encoded image.
    Top
