ArcGIS.Core.CIM Namespace / CIMPointSymbolCallout Class
    CIMPointSymbolCallout Class Properties
    For a list of all members of this type, see CIMPointSymbolCallout members.
    Public Properties
     NameDescription
    Public Property Gets or sets an enumeration value that defines how the background is scaled to fit the dimensions of the symbol.
    Public Property Gets or sets the gap (in points) between the text symbol and the beginning of the leader line. (Inherited from ArcGIS.Core.CIM.CIMLineCallout)
    Public Property Gets or sets the line symbol to draw leaders with. (Inherited from ArcGIS.Core.CIM.CIMLineCallout)
    Public Property Gets or sets the leader offset which is an offset value defining the distance (in points) between the anchor point and the beginning of the drawn leader. (Inherited from ArcGIS.Core.CIM.CIMCallout)
    Public Property Gets or sets the leader tolerance which is the closest distance (in points) to the text the anchor point can be for the callout to draw. (Inherited from ArcGIS.Core.CIM.CIMCallout)
    Public Property Gets or sets the style of line to generate when a Point leader is drawn defined by an enumeration value. Line leaders will always be drawn with their own geometry. (Inherited from ArcGIS.Core.CIM.CIMLineCallout)
    Public Property Gets or sets the symbol that will be drawn as the background behind the text. The most common use case for this type of symbol is a highway shield. When drawing a highway shield this property will be the shield itself without numbers.
    Top
