ArcGIS.Core.CIM Namespace / CIMRandomHSVColorRamp Class
    CIMRandomHSVColorRamp Class Properties
    For a list of all members of this type, see CIMRandomHSVColorRamp members.
    Public Properties
     NameDescription
    Public Property Gets or sets the color space of the color. This color space is defined by an ICC color profile. (Inherited from ArcGIS.Core.CIM.CIMColorRamp)
    Public Property Gets or sets the maximum alpha or transparency for all of the colors. Can be a value between 0-100, where 0 is fully transparent.
    Public Property Gets or sets the hue at which the color ramp (also known as a color scheme) will end. Values can range from 0-360.
    Public Property Gets or sets the maximum saturation possible for the colors within the color ramp (also known as a color scheme). Values can range between 0-100.
    Public Property Gets or sets the maximum value possible for the colors within the color ramp (also known as a color scheme). Values can range between 0-100.
    Public Property Gets or sets the minimum alpha or transparency for all of the colors. Can be a value between 0-100, where 0 is fully transparent.
    Public Property Gets or sets the hue from which the color ramp (also known as a color scheme) will start. Values can range from 0-360.
    Public Property Gets or sets the minimum saturation possible for the colors within the color ramp (also known as a color scheme). Values can range between 0-100.
    Public Property Gets or sets the minimum value possible for the colors within the ramp (also known as a scheme). Values can range between 0-100.
    Public Property Gets or sets the starting point for the random generation of the colors.
    Top
