ArcGIS.Core.CIM Namespace / CIMBackgroundCallout Class
    CIMBackgroundCallout Class Properties
    For a list of all members of this type, see CIMBackgroundCallout members.
    Public Properties
     NameDescription
    Public Property Gets or sets the symbol used to draw the accent bar. If null, the accent bar doesn't draw.
    Public Property Gets or sets the symbol used to draw the background. If null, the background doesn't draw.
    Public Property Gets or sets the gap (in points) between the text symbol and the beginning of the leader line. (Inherited from ArcGIS.Core.CIM.CIMLineCallout)
    Public Property Gets or sets the line symbol to draw leaders with. (Inherited from ArcGIS.Core.CIM.CIMLineCallout)
    Public Property Gets or sets the leader offset which is an offset value defining the distance (in points) between the anchor point and the beginning of the drawn leader. (Inherited from ArcGIS.Core.CIM.CIMCallout)
    Public Property Gets or sets the leader tolerance which is the closest distance (in points) to the text the anchor point can be for the callout to draw. (Inherited from ArcGIS.Core.CIM.CIMCallout)
    Public Property Gets or sets the style of line to generate when a Point leader is drawn defined by an enumeration value. Line leaders will always be drawn with their own geometry. (Inherited from ArcGIS.Core.CIM.CIMLineCallout)
    Public Property Gets or sets the text margin defining the space around the text that is accounted for in background creation.
    Top
