Public Class CIMStandardGeneralPlacementProperties Inherits CIMGeneralPlacementProperties Implements System.ComponentModel.INotifyPropertyChanged, System.Xml.Serialization.IXmlSerializable
public class CIMStandardGeneralPlacementProperties : CIMGeneralPlacementProperties, System.ComponentModel.INotifyPropertyChanged, System.Xml.Serialization.IXmlSerializable
// Note: call within QueuedTask.Run()
//Get the active map's definition - CIMMap.
var cimMap = MapView.Active.Map.GetDefinition();
//Get the labeling engine from the map definition
var cimGeneralPlacement = cimMap.GeneralPlacementProperties;
if (cimGeneralPlacement is CIMMaplexGeneralPlacementProperties)
//Current labeling engine is Maplex labeling engine
//Create a new standard label engine properties
var cimStandardPlacementProperties = new CIMStandardGeneralPlacementProperties();
//Set the CIMMap's GeneralPlacementProperties to the new label engine
cimMap.GeneralPlacementProperties = cimStandardPlacementProperties;
else
//Current labeling engine is Standard labeling engine
//Create a new Maplex label engine properties
var cimMaplexGeneralPlacementProperties = new CIMMaplexGeneralPlacementProperties();
cimMap.GeneralPlacementProperties = cimMaplexGeneralPlacementProperties;
//Set the map's definition
MapView.Active.Map.SetDefinition(cimMap);
System.Object
ArcGIS.Core.CIM.CIMObject
ArcGIS.Core.CIM.CIMGeneralPlacementProperties
ArcGIS.Core.CIM.CIMStandardGeneralPlacementProperties
