ArcGIS.Core.CIM Namespace / CIMTableView Class
    CIMTableView Class Properties
    For a list of all members of this type, see CIMTableView members.
    Public Properties
     NameDescription
    Public Property Gets or sets a value indicating whether other contingent value fields should be automatically populated after a value is changed when only one match is valid.
    Public Property Gets or sets a value indicating the height for the column header row in the table.
    Public Property Gets or sets a value indicating whether to display subtype and domain descriptions.
    Public Property Gets or sets the extent of the table view.
    Public Property Gets or sets the field order as a string of field names.
    Public Property Gets or sets a property set of field width information.
    Public Property Gets or sets the count of frozen fields.
    Public Property Gets or sets a value indicating whether invalid contingent value fields should be highlighted in the table.
    Public Property Gets or sets a value indicating whether to honor ranges on the table view.
    Public Property Gets or sets a value indicating whether to honor time on the table view.
    Public Property Gets or sets the instance identifier of this view. (Inherited from ArcGIS.Core.CIM.CIMView)
    Public Property Gets or sets a value indicating whether to qualify field names when the table contains fields from a join.
    Public Property Gets or sets the ranges of the table view.
    Public Property Gets or sets a value indicating the height for the rows in the table.
    Public Property Gets or sets a value indicating whether to view the table in selection mode.
    Public Property Gets or sets a value indicating whether the table field visibility settings should be overridden to only show fields that are part of one or more contingent value field groups.
    Public Property Gets or sets a property set containing sort information.
    Public Property Gets or sets the current time of the table view.
    Public Property Gets or sets a time relation which allows the start and end times to be included or excluded in the time query.
    Public Property Gets or sets the path of the item in the view. (Inherited from ArcGIS.Core.CIM.CIMView)
    Public Property Gets or sets the view type as a string. (Inherited from ArcGIS.Core.CIM.CIMView)
    Public Property Gets or sets the zoom level of the table view.
    Top
