ArcGIS.Core.CIM Namespace / CIMTextSymbol Class
Members Example
    CIMTextSymbol Class
    Represents a text symbol which is used to draw text graphics, bleeds, and annotation. Text symbols do not contain any symbol layers but can have callouts.
    Object Model
    CIMTextSymbol ClassCIMCallout ClassCIMTextSymbol ClassCIMTextSymbol ClassCIMPolygonSymbol ClassCIMColor ClassCIMPolygonSymbol ClassCIM3DSymbolProperties Class
    Syntax
    Example
    Create Point Text Element 1
      //Create a simple point text element and assign basic symbology and text settings.
      //Note: Must be on QueuedTask.Run
      //Build 2D point geometry
      Coordinate2D coord2D = new Coordinate2D(3.5, 10);
      //Set symbology, create and add element to layout
      CIMTextSymbol sym = SymbolFactory.Instance.ConstructTextSymbol(
                    ColorFactory.Instance.RedRGB, 32, "Arial", "Regular");
      string textString = "Point text";
      //use ElementInfo to set placement properties during create
      var elemInfo = new ElementInfo()
        Anchor = Anchor.CenterPoint,
        Rotation = 45
      var ptTxtElm = ElementFactory.Instance.CreateTextGraphicElement(
        layout, TextType.PointText, coord2D.ToMapPoint(), sym, textString,
                           "New Point Text", true, elemInfo);
      //Change additional text properties
      ptTxtElm.SetX(4.5);
      ptTxtElm.SetY(9.5);
    Create Rectangle Paragraph Text Element 1
      //Create rectangle text with background and border symbology.
      //Build 2D polygon geometry
      List<Coordinate2D> plyCoords = new List<Coordinate2D>();
      plyCoords.Add(new Coordinate2D(3.5, 7));
      plyCoords.Add(new Coordinate2D(4.5, 7));
      plyCoords.Add(new Coordinate2D(4.5, 6.7));
      plyCoords.Add(new Coordinate2D(5.5, 6.7));
      plyCoords.Add(new Coordinate2D(5.5, 6.1));
      plyCoords.Add(new Coordinate2D(3.5, 6.1));
      Polygon poly = PolygonBuilderEx.CreatePolygon(plyCoords);
      //Also notice how formatting tags are using within the text string.
                        ColorFactory.Instance.GreyRGB, 10, "Arial", "Regular");
      string text = "Some Text String that is really long and is " +
                    "<BOL>forced to wrap to other lines</BOL> so that " +
                    "we can see the effects." as String;
      GraphicElement polyTxtElm = ElementFactory.Instance.CreateTextGraphicElement(
        layout, TextType.RectangleParagraph, poly, sym, text, "Polygon Paragraph");
      //(Optionally) Modify paragraph border
      CIMGraphic polyTxtGra = polyTxtElm.GetGraphic();
      CIMParagraphTextGraphic cimPolyTxtGra = polyTxtGra as CIMParagraphTextGraphic;
      cimPolyTxtGra.Frame.BorderSymbol = new CIMSymbolReference();
      cimPolyTxtGra.Frame.BorderSymbol.Symbol =
                   SymbolFactory.Instance.ConstructLineSymbol(
                              ColorFactory.Instance.GreyRGB, 1.0, SimpleLineStyle.Solid);
      polyTxtElm.SetGraphic(polyTxtGra);
    Create elements on a presentation page
      //create a picture element
      var imgPath = @"https://www.esri.com/content/dam/esrisites/en-us/home/" +
       "homepage-tile-podcast-business-resilience-climate-change.jpg";
      //Build a geometry to place the picture
      Coordinate2D ll = new Coordinate2D(3.5, 1);
      Coordinate2D ur = new Coordinate2D(6, 5);
      Envelope env = EnvelopeBuilderEx.CreateEnvelope(ll, ur);
      //create a picture element on the page
      var gElement = PresentationElementFactory.Instance.CreatePictureGraphicElement(page, env, imgPath);
      //create a text element
      //Set symbology, create and add element to a presentation page
                    ColorFactory.Instance.RedRGB, 15, "Arial", "Regular");
        Rotation = 45
      string textString = "My text";
      var textPos = new Coordinate2D(5, 3).ToMapPoint();
      var tElement = PresentationElementFactory.Instance.CreateTextGraphicElement(page,
        TextType.PointText, textPos, sym, textString, "telement", false, elemInfo);
      //create a group element with elements created above
      var elmList = new List<Element> { gElement, tElement };
      GroupElement grp1 = PresentationElementFactory.Instance.CreateGroupElement(page, elmList, "My Group");
    Inheritance Hierarchy
    System.Object
       ArcGIS.Core.CIM.CIMObject
          ArcGIS.Core.CIM.CIMSymbol
             ArcGIS.Core.CIM.CIMTextSymbol
    Requirements
