ArcGIS.Core.CIM Namespace / CIMTinContourRenderer Class
    CIMTinContourRenderer Class Properties
    For a list of all members of this type, see CIMTinContourRenderer members.
    Public Properties
     NameDescription
    Public Property Gets or sets the contour description.
    Public Property Gets or sets the contour interval.
    Public Property Gets or sets the contour interval scale breaks. The scale breaks should be ordered from the smallest scale to the largest. The last scale break's upper bound will always be treated as 0, indicating no upper bound.
    Public Property Gets or sets the contour label.
    Public Property Gets or sets the contour symbol.
    Public Property Gets or sets a value indicating whether or not to illuminate. (Inherited from ArcGIS.Core.CIM.CIMTinRenderer)
    Public Property Gets or sets the index contour description.
    Public Property Gets or sets the index contour factor.
    Public Property Gets or sets the index contour label.
    Public Property Gets or sets the index contour symbol.
    Public Property Gets or sets the maximum scale for renderer draw (set as the denominator of the scale's representative fraction). Values less than or equal to 0 indicate there is no maximum scale and the renderer will draw at any scale above the minimum. (Inherited from ArcGIS.Core.CIM.CIMTinRenderer)
    Public Property Gets or sets the minimum scale for renderer draw (set as the denominator of the scale's representative fraction). Values less than or equal to 0 indicate there is no minimum scale and the renderer will draw at any scale below the maximum. (Inherited from ArcGIS.Core.CIM.CIMTinRenderer)
    Public Property Gets or sets the reference contour height.
    Public PropertyGets or sets a value indicating whether scale-dependent intervals are used. If true, ContourIntervalScaleBreaks are used; if false, ContourInterval is used at all scales.
    Top
