ArcGIS.Core.CIM Namespace / NASolverDefinition Class
    NASolverDefinition Class Properties
    For a list of all members of this type, see NASolverDefinition members.
    Public Properties
     NameDescription
    Public Property Gets and sets the accumulate attribute names.
    Public Property Gets and sets the applied travel mode.
    Public Property Gets and sets the applied travel mode as JSON.
    Public Property Gets and sets the attribute names.
    Public Property Gets and sets the attribute parameters values.
    Public Property Gets and sets the name of the hierarchy attribute to be used in analysis.
    Public Property Gets and sets the hierarchy level count.
    Public Property Gets and sets the maximum value of the hierarchy attribute.
    Public Property Gets and sets the number of lower level junctions to explore before searching the next hierarchy level.
    Public Property Gets and sets a boolean which indicates whether or not to ignore invalid locations.
    Public Property Gets and sets the impedance attribute name.
    Public Property Gets and sets the associated network build hash.
    Public Property Gets and sets the output geometry precision.
    Public Property Gets and sets the output geometry precision units.
    Public Property Gets and sets a boolean which indicates if the hierarchy ranges will be reset to the network dataset's hierarchy settings when the solver is bound.
    Public Property Gets and sets the restriction attribute names.
    Public Property Gets and sets a setting which indicates how U-Turns should be restricted in the analysis.
    Public Property Gets and sets the associated solver overrides.
    Public Property Gets and sets a boolean which indicates if the hierarchy attribute for the network should be used in analysis.
    Top
