ArcGIS.Core.Data Namespace / FieldType Enumeration
Example Example
    Specifies the data type of the field.
    Syntax
    Members
    MemberDescription
    BigInteger 64-bit Integer.
    Blob Binary Large Object.
    Date Date.
    DateOnly Date Only.
    Double Double-precision floating-point number.
    Geometry Geometry.
    GlobalID Esri Global ID.
    GUID Globally Unique Identifier.
    Integer 32-bit Integer.
    OID Integer representing an object identifier. 32-bit OID has a length of 4 bytes, and 64-bit OID has a length of 8 bytes.
    Raster Raster.
    Single Single-precision floating-point number.
    SmallInteger 16-bit Integer.
    String Character string.
    TimeOnly Time Only.
    TimestampOffset Timestamp Offset. DateTime value, together with an offset.
    XML XML Document.
    Example
    64-bit Integer field
      FieldDescription bigIntegerFieldDescription =
        new FieldDescription("BigInteger_64", FieldType.BigInteger);
    ObjectID field
      // 64-bit
      FieldDescription oidFieldDescription_64 =
        new FieldDescription("ObjectID_64", FieldType.OID)
          Length = 8
      // 32-bit
      FieldDescription oidFieldDescription_32 =
        new FieldDescription("ObjectID_32", FieldType.OID)
          Length = 4
    DateOnly, TimeOnly, and TimestampOffset field
      // Earthquake occurrences date and time
      // 9/28/2014 (DateOnly)
      FieldDescription earthquakeDateOnlyFieldDescription =
        new FieldDescription("Earthquake_DateOnly", FieldType.DateOnly);
      // 1:16:42 AM (TimeOnly)
      FieldDescription earthquakeTimeOnlyFieldDescription =
        new FieldDescription("Earthquake_TimeOnly", FieldType.TimeOnly);
      // 9/28/2014 1:16:42.000 AM -09:00 (Timestamp with Offset)
      FieldDescription earthquakeTimestampOffsetFieldDescription =
        new FieldDescription("Earthquake_TimestampOffset_Local", FieldType.TimestampOffset);
      // 9/28/2014 1:16:42 AM (DateTime)
      FieldDescription earthquakeDateFieldDescription =
        new FieldDescription("Earthquake_Date", FieldType.Date);
    Creating a FeatureDataset with a FeatureClass in one operation
      // Must be called within QueuedTask.Run
      void CreateFeatureDatasetWithFeatureClassSnippet(Geodatabase geodatabase)
        // Creating a FeatureDataset named as 'Parcel_Information' and a FeatureClass with name 'Parcels' in one operation
        string featureDatasetName = "Parcel_Information";
        string featureClassName = "Parcels";
        SchemaBuilder schemaBuilder = new SchemaBuilder(geodatabase);
        // Create a FeatureDataset token
        FeatureDatasetDescription featureDatasetDescription = new FeatureDatasetDescription(featureDatasetName, SpatialReferences.WGS84);
        FeatureDatasetToken featureDatasetToken = schemaBuilder.Create(featureDatasetDescription);
        // Create a FeatureClass description
        FeatureClassDescription featureClassDescription = new FeatureClassDescription(featureClassName,
          new List<FieldDescription>()
              new FieldDescription("Id", FieldType.Integer),
              new FieldDescription("Address", FieldType.String)
          new ShapeDescription(GeometryType.Point, SpatialReferences.WGS84));
        // Create a FeatureClass inside a FeatureDataset
        FeatureClassToken featureClassToken = schemaBuilder.Create(
          new FeatureDatasetDescription(featureDatasetToken),
          featureClassDescription);
        // Build status
        bool buildStatus = schemaBuilder.Build();
        // Build errors
        if (!buildStatus)
          IReadOnlyList<string> errors = schemaBuilder.ErrorMessages;
    Creating a FeatureClass in existing FeatureDataset
      void CreateFeatureClassInsideFeatureDatasetSnippet(Geodatabase geodatabase)
        // Creating a FeatureClass named as 'Tax_Jurisdiction' in existing FeatureDataset with name 'Parcels_Information'
        string featureDatasetName = "Parcels_Information";
        string featureClassName = "Tax_Jurisdiction";
              new FieldDescription("Tax_Id", FieldType.Integer),
        FeatureDatasetDefinition featureDatasetDefinition = geodatabase.GetDefinition<FeatureDatasetDefinition>(featureDatasetName);
        // Create a FeatureClass inside a FeatureDataset using a FeatureDatasetDefinition
        schemaBuilder.Create(new FeatureDatasetDescription(featureDatasetDefinition), featureClassDescription);
        // Build status
        // Build errors
        if (!buildStatus)
    Inheritance Hierarchy
    System.Object
       System.ValueType
          System.Enum
             ArcGIS.Core.Data.FieldType
    Requirements
