Return Value
The geometry of this feature.
| Exception | Description |
| ArcGIS.Core.Geometry.Exceptions.GeometryException | This feature's type of shape (i.e., geometry) is not supported. |
| ArcGIS.Core.Data.Exceptions.GeodatabaseException | A geodatabase-related exception has occurred. |
// methods need to run on the MCT
ArcGIS.Desktop.Framework.Threading.Tasks.QueuedTask.Run(() =>
try
// open a gdb
using (ArcGIS.Core.Data.Geodatabase gdb =
new ArcGIS.Core.Data.Geodatabase(
new FileGeodatabaseConnectionPath(new Uri(@"c:\Temp\MyDatabase.gdb"))))
//Open a featureClass
using (ArcGIS.Core.Data.FeatureClass featureClass =
gdb.OpenDataset<ArcGIS.Core.Data.FeatureClass>("Polygon"))
ArcGIS.Core.Data.QueryFilter filter =
new ArcGIS.Core.Data.QueryFilter()
WhereClause = "OBJECTID = 6"
// get the row
using (ArcGIS.Core.Data.RowCursor rowCursor =
featureClass.Search(filter, false))
while (rowCursor.MoveNext())
using (var row = rowCursor.Current)
long oid = row.GetObjectID();
// get the shape from the row
ArcGIS.Core.Data.Feature feature = row as ArcGIS.Core.Data.Feature;
Polygon polygon = feature.GetShape() as Polygon;
// do something here
catch (Exception ex)
// error - handle appropriately
//Change map frame extent to single feature with 10 percent buffer
//Note: Must be on QueuedTask.Run
//Reference the mapframe and its associated map
Map m = mapFrame.Map;
//Reference a feature layer and build a query (to return a single feature)
FeatureLayer fl = m.FindLayers("GreatLakes").First() as FeatureLayer;
QueryFilter qf = new QueryFilter();
string whereClause = "NAME = 'Lake Erie'";
qf.WhereClause = whereClause;
//Zoom to the feature
using (ArcGIS.Core.Data.RowCursor rowCursor = fl.Search(qf))
//Get the shape from the row and set extent
using (var feature = rowCursor.Current as ArcGIS.Core.Data.Feature)
Envelope env = polygon.Extent as Envelope;
mapFrame.SetCamera(env);
//Zoom out 15 percent
Camera cam = mapFrame.Camera;
cam.Scale = cam.Scale * 1.15;
mapFrame.SetCamera(cam);
