ArcGIS.Core.Data Namespace / FeatureDatasetDefinition Class
Members Example
    Represents the properties of a FeatureDataset.
    Object Model
    FeatureDatasetDefinition ClassEnvelope ClassSpatialReference Class
    Syntax
    Public NotInheritable Class FeatureDatasetDefinition
       Inherits Definition
       Implements System.IDisposable
    public sealed class FeatureDatasetDefinition : Definition, System.IDisposable
    Example
    Obtaining Definition from Geodatabase
      await QueuedTask.Run(() =>
        using (Geodatabase geodatabase = new Geodatabase(new DatabaseConnectionFile(new Uri("path\\to\\sde\\file\\sdefile.sde"))))
          // Remember that for Enterprise databases you have to qualify your dataset names with the DatabaseName and UserName.
          TableDefinition enterpriseTableDefinition = geodatabase.GetDefinition<TableDefinition>("LocalGovernment.GDB.CitizenContactInfo");
          // It does not matter if the dataset is within a FeatureDataset or not.
          FeatureClassDefinition featureClassDefinition = geodatabase.GetDefinition<FeatureClassDefinition>("LocalGovernment.GDB.FireStation");
          // GetDefinition For a RelationshipClass.
          RelationshipClassDefinition relationshipClassDefinition = geodatabase.GetDefinition<RelationshipClassDefinition>(
              "LocalGovernment.GDB.AddressPointHasSiteAddresses");
          // GetDefinition For a FeatureDataset.
          FeatureDatasetDefinition featureDatasetDefinition = geodatabase.GetDefinition<FeatureDatasetDefinition>("LocalGovernment.GDB.Address");
    Obtaining List of Definitions from Geodatabase
          IReadOnlyList<FeatureClassDefinition> enterpriseDefinitions = geodatabase.GetDefinitions<FeatureClassDefinition>();
          IEnumerable<Definition> featureClassesHavingGlobalID = enterpriseDefinitions.Where(definition => definition.HasGlobalID());
          IReadOnlyList<FeatureDatasetDefinition> featureDatasetDefinitions = geodatabase.GetDefinitions<FeatureDatasetDefinition>();
          bool electionRelatedFeatureDatasets = featureDatasetDefinitions.Any(definition => definition.GetName().Contains("Election"));
          IReadOnlyList<AttributedRelationshipClassDefinition> attributedRelationshipClassDefinitions = geodatabase.GetDefinitions<AttributedRelationshipClassDefinition>();
          IReadOnlyList<RelationshipClassDefinition> relationshipClassDefinitions = geodatabase.GetDefinitions<RelationshipClassDefinition>();
    Deleting a FeatureDataset
      // Must be called within QueuedTask.Run
      void DeleteFeatureDatasetSnippet(Geodatabase geodatabase)
        // Deleting a FeatureDataset named as 'Parcel_Information'
        FeatureDatasetDefinition featureDatasetDefinition = geodatabase.GetDefinition<FeatureDatasetDefinition>("Parcel_Information");
        FeatureDatasetDescription featureDatasetDescription = new FeatureDatasetDescription(featureDatasetDefinition);
        SchemaBuilder schemaBuilder = new SchemaBuilder(geodatabase);
        // Delete an existing feature dataset named as 'Parcel_Information'
        schemaBuilder.Delete(featureDatasetDescription);
        schemaBuilder.Build();
    Inheritance Hierarchy
    System.Object
       ArcGIS.Core.CoreObjectsBase
          ArcGIS.Core.Data.Definition
             ArcGIS.Core.Data.FeatureDatasetDefinition
    Requirements
