GetDefinition<T> Method (Geodatabase)
Gets a specific
Definition instance associated with of type in the geodatabase. This method must be called on the MCT. Use QueuedTask.Run.
Parameters
- name
The name of the dataset.
Type Parameters
- T
The type of dataset definition.
Return Value
A specific
Definition instance corresponding to type .
Obtaining Definition from Geodatabase
await QueuedTask.Run(() =>
using (Geodatabase geodatabase = new Geodatabase(new DatabaseConnectionFile(new Uri("path\\to\\sde\\file\\sdefile.sde"))))
// Remember that for Enterprise databases you have to qualify your dataset names with the DatabaseName and UserName.
TableDefinition enterpriseTableDefinition = geodatabase.GetDefinition<TableDefinition>("LocalGovernment.GDB.CitizenContactInfo");
// It does not matter if the dataset is within a FeatureDataset or not.
FeatureClassDefinition featureClassDefinition = geodatabase.GetDefinition<FeatureClassDefinition>("LocalGovernment.GDB.FireStation");
// GetDefinition For a RelationshipClass.
RelationshipClassDefinition relationshipClassDefinition = geodatabase.GetDefinition<RelationshipClassDefinition>(
"LocalGovernment.GDB.AddressPointHasSiteAddresses");
// GetDefinition For a FeatureDataset.
FeatureDatasetDefinition featureDatasetDefinition = geodatabase.GetDefinition<FeatureDatasetDefinition>("LocalGovernment.GDB.Address");
Obtaining Definitions from a Feature Service by Layer ID
//Url examples for (federated) feature services
//(by "ref" online):
var url =
@"https://sampleserver6.arcgisonline.com/arcgis/rest/services/SF311/FeatureServer";
//(federated by ref on portal)
//https://portal.example.com/server/rest/services/FeatureServiceName/FeatureServer");
//(federated by value - Hosted - on portal)
//https://portal.example.com/server/rest/services/Hosted/FeatureServiceName/FeatureServer");
var uri = new Uri(url, UriKind.Absolute);
using (var fs_db = new ArcGIS.Core.Data.Geodatabase(new ServiceConnectionProperties(uri)))
//Assuming that id 0 is a FeatureClass for the given service
fs_db.GetDefinition<FeatureClassDefinition>("0");
string shapeField = featureClassDefinition.GetShapeField();
IReadOnlyList<Field> fields = featureClassDefinition.GetFields();
//Assuming that id 1 is a Table for the given service
TableDefinition tableDefinition =
fs_db.GetDefinition<TableDefinition>("1");
string objectIDField = tableDefinition.GetObjectIDField();
Checking for the existence of a Table
//Must be called within QueuedTask.Run().
bool TableExists(Geodatabase geodatabase, string tableName)
try
using TableDefinition tableDefinition =
geodatabase.GetDefinition<TableDefinition>(tableName);
return true;
catch
// GetDefinition throws an exception if the definition doesn't exist
return false;
Checking for the existence of a Feature Class
bool FeatureClassExists(Geodatabase geodatabase, string featureClassName)
try
using FeatureClassDefinition featureClassDefinition =
geodatabase.GetDefinition<FeatureClassDefinition>(featureClassName);
return true;
catch
return false;
