ArcGIS.Core.Data Namespace / Geodatabase Class / IsVersioningSupported Method
Example
    Gets a value indicating whether this geodatabase supports versioning. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Function IsVersioningSupported() As Boolean
    public bool IsVersioningSupported()
    Return Value
    true if this geodatabase supports versioning and was not returned from HistoricalVersion.Connect. false otherwise.
    Exceptions
    ExceptionDescription
    No valid geodatabase has been opened prior to invoking this operation.
    Example
    Connecting to a Version
      // Must be called within QueuedTask.Run
      Geodatabase ConnectToVersion(Geodatabase geodatabase, string versionName)
        Geodatabase connectedVersion = null;
        if (geodatabase.IsVersioningSupported())
          using (VersionManager versionManager = geodatabase.GetVersionManager())
          using (Version version = versionManager.GetVersion(versionName))
            connectedVersion = version.Connect();
        return connectedVersion;
    Reconciling and Posting a Version with its Parent in separate edit sessions
      void ReconcileAndPost(Geodatabase geodatabase)
        // Get a reference to our version and our parent
          using (Version currentVersion = versionManager.GetCurrentVersion())
          using (Version parentVersion = currentVersion.GetParent())
            // Create a ReconcileOptions object
            ReconcileOptions reconcileOptions = new ReconcileOptions(parentVersion);
            reconcileOptions.ConflictResolutionMethod = ConflictResolutionMethod.Continue; // continue if conflicts are found
            reconcileOptions.ConflictDetectionType = ConflictDetectionType.ByRow; //Default
            reconcileOptions.ConflictResolutionType = ConflictResolutionType.FavorTargetVersion; //or FavorEditVersion
            // Reconcile
            ReconcileResult reconcileResult = currentVersion.Reconcile(reconcileOptions);
            if (!reconcileResult.HasConflicts)
              //No conflicts, perform the post
              PostOptions postOptions = new PostOptions(parentVersion);
              //var postOptions = new PostOptions(); for default version
              postOptions.ServiceSynchronizationType = ServiceSynchronizationType.Synchronous; //Default
              // Post - Deprecated since Pro SDK 3.6 / Enterprise 12.0 . Use Reconcile(reconcileOptions, postOptions) instead.
              // currentVersion.Post(postOptions);
              currentVersion.Reconcile(reconcileOptions, postOptions);
    Reconciling and Posting a Version with its Parent in the same edit session
      void ReconcileAndPost2(Geodatabase geodatabase)
            // Reconcile
            ReconcileResult reconcileResult = currentVersion.Reconcile(reconcileOptions, postOptions);
            if (reconcileResult.HasConflicts)
              //TODO resolve conflicts
    Requirements
