ArcGIS.Core.Geometry Namespace / AttributeFlags Enumeration
Example Example
    Flags used when creating a geometry in some GeometryBuilderEx methods specifying which attributes, Z, M, and ID, the newly created geometry should have. Use bitwise OR to specify more than one attribute. For example, to specify that the geometry should have Z and M-values, specify AttributeFlags.HasZ | AttributeFlags.HasM.
    Syntax
    Members
    MemberDescription
    AllAttributes Specifies that the geometry has Z, M and ID-values.
    HasID Specifies that the geometry has ID-values.
    HasM Specified that the geometry has M-values.
    HasZ Specifies that the geometry has Z-values.
    None Specifies that the geometry has no attributes. It does not have Z, M or ID-values.
    Example
    Builder Properties
      // list of points
      List<MapPoint> pointsForBuilder = new List<MapPoint>
      MapPointBuilderEx.CreateMapPoint(0, 0, 2, 3, 1),
      MapPointBuilderEx.CreateMapPoint(1, 1, 5, 6),
      MapPointBuilderEx.CreateMapPoint(2, 1, 6),
      MapPointBuilderEx.CreateMapPoint(0, 0)
      // will have attributes because it is created with convenience method
      Polyline polylineWithAttrs = PolylineBuilderEx.CreatePolyline(pointsForBuilder);
      bool hasZ = polylineWithAttrs.HasZ;          // hasZ = true
      bool hasM = polylineWithAttrs.HasM;          // hasM = true
      bool hasID = polylineWithAttrs.HasID;        // hasID = true
      // will not have attributes because it is specified as a parameter
      Polyline polylineWithoutAttrs =
        PolylineBuilderEx.CreatePolyline(pointsForBuilder, AttributeFlags.None);
      hasZ = polylineWithoutAttrs.HasZ;          // hasZ = false
      hasM = polylineWithoutAttrs.HasM;          // hasM = false
      hasID = polylineWithoutAttrs.HasID;        // hasID = false
      Polygon polygonWithAttrs = PolygonBuilderEx.CreatePolygon(pointsForBuilder);
      hasZ = polygonWithAttrs.HasZ;               // hasZ = true
      hasM = polygonWithAttrs.HasM;               // hasM = true
      hasID = polygonWithAttrs.HasID;             // hasID = true
      Polygon polygonWithoutAttrs =
            PolygonBuilderEx.CreatePolygon(pointsForBuilder, AttributeFlags.None);
      hasZ = polygonWithoutAttrs.HasZ;               // hasZ = false
      hasM = polygonWithoutAttrs.HasM;               // hasM = false
      hasID = polygonWithoutAttrs.HasID;             // hasID = false
      PolylineBuilderEx polylineB =
                 new PolylineBuilderEx(pointsForBuilder, AttributeFlags.None);
      hasZ = polylineB.HasZ;                      // hasZ = false
      hasM = polylineB.HasM;                      // hasM = false
      hasID = polylineB.HasID;                    // hasID = false
      // will have attributes because it is passed an attributed polyline
      polylineB = new PolylineBuilderEx(polylineWithAttrs);
      hasZ = polylineB.HasZ;                      // hasZ = true
      hasM = polylineB.HasM;                      // hasM = true
      hasID = polylineB.HasID;                    // hasID = true
      // will not have attributes because it is passed a non-attributed polyline
      polylineB = new PolylineBuilderEx(polylineWithoutAttrs);
      PolygonBuilderEx polygonB = new PolygonBuilderEx(pointsForBuilder, AttributeFlags.None);
      hasZ = polygonB.HasZ;                       // hasZ = false
      hasM = polygonB.HasM;                       // hasM = false
      hasID = polygonB.HasID;                     // hasID = false
      // will have attributes because it is passed an attributed polygon
      polygonB = new PolygonBuilderEx(polygonWithAttrs);
      hasZ = polygonB.HasZ;                       // hasZ = true
      hasM = polygonB.HasM;                       // hasM = true
      hasID = polygonB.HasID;                     // hasID = true
      // will not have attributes because it is passed a non-attributed polygon
      polygonB = new PolygonBuilderEx(polygonWithoutAttrs);
    Construct a Polyline - from an enumeration of MapPoints
      // Use a builderEx convenience method or a builderEx constructor.
      // neither need to run on the MCT
      MapPoint startPt = MapPointBuilderEx.CreateMapPoint(1.0, 1.0);
      MapPoint endPt = MapPointBuilderEx.CreateMapPoint(2.0, 1.0);
      List<MapPoint> list = new List<MapPoint>() { startPt, endPt };
      Polyline polylineFromPointList = PolylineBuilderEx.CreatePolyline(list, SpatialReferences.WGS84);
      // use AttributeFlags.None since we only have 2D points in the list
      PolylineBuilderEx pb = new PolylineBuilderEx(list, AttributeFlags.None);
      pb.SpatialReference = SpatialReferences.WGS84;
      Polyline polyline2 = pb.ToGeometry();
      // Use AttributeFlags.NoAttributes because we only have 2d points in the list
      Polyline polyline4 = PolylineBuilderEx.CreatePolyline(list, AttributeFlags.None);
    Build a multi-part Polyline
      List<MapPoint> firstPoints = new List<MapPoint>();
      firstPoints.Add(MapPointBuilderEx.CreateMapPoint(1.0, 1.0));
      firstPoints.Add(MapPointBuilderEx.CreateMapPoint(1.0, 2.0));
      firstPoints.Add(MapPointBuilderEx.CreateMapPoint(2.0, 2.0));
      firstPoints.Add(MapPointBuilderEx.CreateMapPoint(2.0, 1.0));
      List<MapPoint> nextPoints = new List<MapPoint>();
      nextPoints.Add(MapPointBuilderEx.CreateMapPoint(11.0, 1.0));
      nextPoints.Add(MapPointBuilderEx.CreateMapPoint(11.0, 2.0));
      nextPoints.Add(MapPointBuilderEx.CreateMapPoint(12.0, 2.0));
      nextPoints.Add(MapPointBuilderEx.CreateMapPoint(12.0, 1.0));
      // use AttributeFlags.None since we have 2D points in the list
      PolylineBuilderEx pBuilder = new PolylineBuilderEx(firstPoints, AttributeFlags.None);
      pBuilder.AddPart(nextPoints);
      Polyline polylineFromBuilder = pBuilder.ToGeometry();
      // polyline has 2 parts
      pBuilder.RemovePart(0);
      // polyline has 1 part
    Inheritance Hierarchy
    System.Object
       System.ValueType
          System.Enum
             ArcGIS.Core.Geometry.AttributeFlags
    Requirements
