await QueuedTask.Run(() =>
// Connects to the default memory geodatabase, if exists otherwise throws exception
MemoryConnectionProperties memoryConnectionProperties = new MemoryConnectionProperties();
// Alternatively, connects to memory geodatabase named as 'InterimMemoryGeodatabase'
// MemoryConnectionProperties memoryConnectionProperties = new MemoryConnectionProperties("InterimMemoryGeodatabase");
// Opens the memory geodatabase
using (Geodatabase geodatabase = new Geodatabase(memoryConnectionProperties))
// Use memory geodatabase
// Create the memory connection properties to connect to default memory geodatabase
// Alternatively create the memory connection properties to connect to memory geodatabase named as 'InterimMemoryGeodatabase'
// Creates the new memory geodatabase if it does not exist or connects to an existing one if it already exists
// Create additional schema here
// Delete the memory geodatabase
SchemaBuilder.DeleteGeodatabase(memoryConnectionProperties);
System.Object
ArcGIS.Core.Data.Connector
ArcGIS.Core.Data.MemoryConnectionProperties
