ArcGIS.Desktop.Core Namespace / EditingOptions Class / EnableEditingFromEditTab Property
Example
    Gets and sets whether editing can be enabled and disabled from the Edit tab.
    Syntax
    Public Property EnableEditingFromEditTab As Boolean
    public bool EnableEditingFromEditTab {get; set;}
    Example
    Start a Single workspace edit session via a MapMember
      // ApplicationOptions.EditingOptions.EnableEditingFromEditTab is true
      // ApplicationOptions.EditingOptions.IsSingleWorkspaceEditSession is true
      // find a layer
      var mm = MapView.Active.Map.GetLayersAsFlattenedList().FirstOrDefault(l => l.Name == "Roads");
      if (mm == null)
        return;
      var project = Project.Current;
      var success = await project.SetSingleEditWorkspaceAsync(mm);
      // if success = true then an edit session was started
      // and project.IsEditingEnabled will be true
    Start a single workspace edit session - Full example
      // check if already editing
      if (project.IsEditingEnabled)
        // save or discard any edits
        if (project.HasEdits)
          var res = MessageBox.Show("Save edits?", "Save Edits?", System.Windows.MessageBoxButton.YesNoCancel);
          if (res == System.Windows.MessageBoxResult.Cancel)
            return;
          else if (res == System.Windows.MessageBoxResult.No)
            await project.DiscardEditsAsync();
          else
            await project.SaveEditsAsync();
        // close the edit session
        await project.SetIsEditingEnabledAsync(false);
      // find a layer
      if (mm == null)
        return;
      // start the edit session on the workspace attached to the layer
    Start a Single workspace edit session via a DatastoreConfiguration
      Geodatabase egdb = new Geodatabase(new DatabaseConnectionFile(new Uri("path\\to\\sde\\file\\sdefile.sde")));
      // setup the configuration to edit the data registered as versioned in the egdb
      var datastoreConfig = new DatastoreConfiguration(egdb, VersionState.Versioned);
      var v_success = await project.SetSingleEditWorkspaceAsync(datastoreConfig);
      // OR
      // setup the configuration to edit the data that is not registered as versioned
      var nonVersionedDatastoreConfig = new DatastoreConfiguration(egdb, VersionState.NonVersioned);
      var nv_success = await project.SetSingleEditWorkspaceAsync(nonVersionedDatastoreConfig);
    Requirements
