ArcGIS.Desktop.Mapping Namespace / MapTool Class / ResetSketchSegmentSymbolOptions Method
    Sets the current sketch segment symbol back to the options defined in the application settings. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Protected Sub ResetSketchSegmentSymbolOptions()
    protected void ResetSketchSegmentSymbolOptions()
    Exceptions
    ExceptionDescription
    Requirements
