ArcGIS.Core.Data.NetworkDiagrams Namespace / DiagramManager Class / GetNetwork<T> Method
    Gets the network related to this diagram manager. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Function GetNetwork(Of T As Dataset)() As T
    public T GetNetwork<T>()
    where T: Dataset
    Type Parameters
    T
    Return Value
    The associated network of this diagram manager.
    Exceptions
    ExceptionDescription
    A geodatabase-related exception has occurred. For example, the diagram manager is invalid.
    This method or property must be called within the lambda passed to QueuedTask.Run
    Requirements
