ArcGIS.Core.Data.NetworkDiagrams Namespace / NetworkDiagram Class
Members Example
    Represents a network diagram.
    Object Model
    NetworkDiagram ClassDiagramManager ClassDiagramTemplate ClassNetworkDiagramInfo ClassDiagramElementsAttributes ClassDiagramElementQueryResult Class
    Syntax
    Public NotInheritable Class NetworkDiagram
       Inherits ArcGIS.Core.CoreObjectsBase
       Implements System.IDisposable
    public sealed class NetworkDiagram : ArcGIS.Core.CoreObjectsBase, System.IDisposable
    Remarks
    New network diagrams can be created using the DiagramManager.CreateNetworkDiagram factory method. Existing network diagrams can be retrieved from the DiagramManager or DiagramTemplate classes.
    Example
    Get Network Diagrams
      static void GetDiagram(UtilityNetwork utilityNetwork, IEnumerable<Guid> globalIDs)
        Envelope extentOfInterest = MapView.Active.Map.GetDefaultExtent();
        using (DiagramManager diagramManager = utilityNetwork.GetDiagramManager())
          // Get all the diagrams
          IReadOnlyList<NetworkDiagram> diagrams = diagramManager.GetNetworkDiagrams();
          // Get a diagram by name
          NetworkDiagram diagram = diagramManager.GetNetworkDiagram(_diagramName);
          // Get diagrams by extent
          diagrams = diagramManager.GetNetworkDiagrams(extentOfInterest);
          // Get diagrams from a set of utility network feature GlobalIDs
          diagrams = diagramManager.GetNetworkDiagrams(globalIDs);
          // Get diagrams from a set of utility network feature GlobalIDs within an extent
          diagrams = diagramManager.GetNetworkDiagrams(extentOfInterest, globalIDs);
    Get a list of Network Diagrams with inconsistent ConsistencyState
      static List<NetworkDiagram> GetInconsistentDiagrams(UtilityNetwork utilityNetwork)
        // Get the DiagramManager from the utility network
          List<NetworkDiagram> networkDiagrams = new List<NetworkDiagram>();
          // Loop through the network diagrams in the diagram manager
          foreach (NetworkDiagram diagram in diagramManager.GetNetworkDiagrams())
            NetworkDiagramInfo diagramInfo = diagram.GetDiagramInfo();
            // If the diagram is not a system diagram and is in an inconsistent state, add it to our list
            if (!diagramInfo.IsSystem &&
                diagram.GetConsistencyState() != NetworkDiagramConsistencyState.DiagramIsConsistent)
              networkDiagrams.Add(diagram);
            else
              diagram.Dispose(); // If we are not returning it we need to Dispose it
          return networkDiagrams;
    Open a diagram pane from a Network Diagram
      // Create a diagram layer from a NetworkDiagram
      static void CreateDiagramLayerFromNetworkDiagram(NetworkDiagram networkDiagram)
        // Create the diagram map
        Map newMap = MapFactory.Instance.CreateMap(networkDiagram.Name, MapType.NetworkDiagram, MapViewingMode.Map);
        // Open the diagram map
        Task<IMapPane> mapPane = ProApp.Panes.CreateMapPaneAsync(newMap, MapViewingMode.Map);
        //Add the diagram to the map
        DiagramLayer diagramLayer = newMap.AddDiagramLayer(networkDiagram);
    Get Diagram from DiagramLayer
      // Get the NetworkDiagram from a DiagramLayer and check its ConsistencyState
      static void GetDiagram(DiagramLayer diagramLayer)
        NetworkDiagram diagram = diagramLayer.GetNetworkDiagram();
        // Get the consistency state from the layer
        DiagramLayerConsistencyState diagramLayerConsistencyState = diagramLayer.ConsistencyState;
        // Or from the diagram
        NetworkDiagramConsistencyState diagramConsistencyState = diagram.GetConsistencyState();
    Create a Network Diagram
      // Create a network diagram from a template and a set of utility network feature GlobalIDs
      static void CreateNetworkDiagram(UtilityNetwork utilityNetwork, IEnumerable<Guid> globalIDs)
          // Get the template
          DiagramTemplate template = diagramManager.GetDiagramTemplate(TemplateName);
          NetworkDiagram diagram = diagramManager.CreateNetworkDiagram(template, globalIDs);
    Get Network Diagram Information as JSON string
      static void GetDiagramContent(UtilityNetwork utilityNetwork)
          NetworkDiagram diagram = diagramManager.GetNetworkDiagram(TemplateName);
          string jsonContent = diagram.GetContent(true, true, true, true);
    Change the Layout of a Network Diagram
      // Change the layout of a network diagram by querying for all the diagram elements, editing their shapes,
      static void ChangeDiagramLayout(DiagramManager diagramManager, string diagramName)
        // Retrieve a diagram
        using (NetworkDiagram diagramTest = diagramManager.GetNetworkDiagram(diagramName))
          // Create a DiagramElementQueryByElementTypes query object to get the diagram elements we want to work with
          DiagramElementQueryByElementTypes query = new DiagramElementQueryByElementTypes();
          query.QueryDiagramJunctionElement = true;
          query.QueryDiagramEdgeElement = true;
          query.QueryDiagramContainerElement = true;
          // Retrieve those diagram elements
          DiagramElementQueryResult elements = diagramTest.QueryDiagramElements(query);
          // Create a NetworkDiagramSubset object to edit this set of diagram elements
          NetworkDiagramSubset subset = new NetworkDiagramSubset();
          subset.DiagramJunctionElements = elements.DiagramJunctionElements;
          subset.DiagramEdgeElements = elements.DiagramEdgeElements;
          subset.DiagramContainerElements = elements.DiagramContainerElements;
          // Save the new layout of the diagram elements
          diagramTest.SaveLayout(subset, true);
    Inheritance Hierarchy
    System.Object
          ArcGIS.Core.Data.NetworkDiagrams.NetworkDiagram
    Requirements
