ArcGIS.Core.Data Namespace / RelationshipClassDefinition Class
Members Example
    Represents the schema and properties of a RelationshipClass.
    Syntax
    Public Class RelationshipClassDefinition
       Inherits Definition
       Implements System.IDisposable
    public class RelationshipClassDefinition : Definition, System.IDisposable
    Example
    Obtaining Definition from Geodatabase
      await QueuedTask.Run(() =>
        using (Geodatabase geodatabase = new Geodatabase(new DatabaseConnectionFile(new Uri("path\\to\\sde\\file\\sdefile.sde"))))
          // Remember that for Enterprise databases you have to qualify your dataset names with the DatabaseName and UserName.
          TableDefinition enterpriseTableDefinition = geodatabase.GetDefinition<TableDefinition>("LocalGovernment.GDB.CitizenContactInfo");
          // It does not matter if the dataset is within a FeatureDataset or not.
          FeatureClassDefinition featureClassDefinition = geodatabase.GetDefinition<FeatureClassDefinition>("LocalGovernment.GDB.FireStation");
          // GetDefinition For a RelationshipClass.
          RelationshipClassDefinition relationshipClassDefinition = geodatabase.GetDefinition<RelationshipClassDefinition>(
              "LocalGovernment.GDB.AddressPointHasSiteAddresses");
          // GetDefinition For a FeatureDataset.
          FeatureDatasetDefinition featureDatasetDefinition = geodatabase.GetDefinition<FeatureDatasetDefinition>("LocalGovernment.GDB.Address");
    Obtaining List of Definitions from Geodatabase
          IReadOnlyList<FeatureClassDefinition> enterpriseDefinitions = geodatabase.GetDefinitions<FeatureClassDefinition>();
          IEnumerable<Definition> featureClassesHavingGlobalID = enterpriseDefinitions.Where(definition => definition.HasGlobalID());
          IReadOnlyList<FeatureDatasetDefinition> featureDatasetDefinitions = geodatabase.GetDefinitions<FeatureDatasetDefinition>();
          bool electionRelatedFeatureDatasets = featureDatasetDefinitions.Any(definition => definition.GetName().Contains("Election"));
          IReadOnlyList<AttributedRelationshipClassDefinition> attributedRelationshipClassDefinitions = geodatabase.GetDefinitions<AttributedRelationshipClassDefinition>();
          IReadOnlyList<RelationshipClassDefinition> relationshipClassDefinitions = geodatabase.GetDefinitions<RelationshipClassDefinition>();
    Obtaining Related Definitions from Geodatabase
          // Remember the qualification of DatabaseName. for the RelationshipClass.
          RelationshipClassDefinition enterpriseDefinition = geodatabase.GetDefinition<RelationshipClassDefinition>("LocalGovernment.GDB.AddressPointHasSiteAddresses");
          IReadOnlyList<Definition> enterpriseDefinitions = geodatabase.GetRelatedDefinitions(enterpriseDefinition,
              DefinitionRelationshipType.DatasetsRelatedThrough);
          FeatureClassDefinition enterpriseAddressPointDefinition = enterpriseDefinitions.First(defn => defn.GetName().Equals("LocalGovernment.GDB.AddressPoint"))
              as FeatureClassDefinition;
          IReadOnlyList<Definition> datasetsInAddressDataset = geodatabase.GetRelatedDefinitions(featureDatasetDefinition,
              DefinitionRelationshipType.DatasetInFeatureDataset);
          FeatureClassDefinition addressPointInAddressDataset = datasetsInAddressDataset.First(defn => defn.GetName().Equals("LocalGovernment.GDB.AddressPoint"))
          RelationshipClassDefinition addressPointHasSiteAddressInAddressDataset = datasetsInAddressDataset.First(defn =>
                defn.GetName().Equals("LocalGovernment.GDB.AddressPointHasSiteAddresses"))
              as RelationshipClassDefinition;
    Obtaining related Feature Classes from a Relationship Class
        using (Geodatabase geodatabase = new Geodatabase(new FileGeodatabaseConnectionPath(new Uri(@"C:\Data\LocalGovernment.gdb"))))
          foreach (RelationshipClassDefinition relationshipClassDefinition in relationshipClassDefinitions)
            IReadOnlyList<Definition> definitions = geodatabase.GetRelatedDefinitions(relationshipClassDefinition, DefinitionRelationshipType.DatasetsRelatedThrough);
            foreach (Definition definition in definitions)
              Debug.WriteLine($"Feature class in the RelationshipClass is:{definition.GetName()}");
    Inheritance Hierarchy
    System.Object
       ArcGIS.Core.CoreObjectsBase
          ArcGIS.Core.Data.Definition
             ArcGIS.Core.Data.RelationshipClassDefinition
                ArcGIS.Core.Data.AttributedRelationshipClassDefinition
    Requirements
