ArcGIS.Core.Data Namespace / Row Class / GetAttachments Method
An optional parameter. If not set or set to null, all attachments associated with this row is returned. Otherwise, only the attachments associated with the valid ID in attachmentIDs is returned.
An optional parameter. If not set or set to false, the entire attachment, including its binary data, is returned.
Example
    Gets a IReadOnlyList of attachments based on the requested attachmentIDs for a given row. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Function GetAttachments( _
       Optional ByVal attachmentIDs As IEnumerable(Of Long), _
       Optional ByVal infoOnly As Boolean _
    ) As IReadOnlyList(Of Attachment)
    Parameters
    attachmentIDs
    infoOnly
    Return Value
    A IReadOnlyList of Attachment. If there are no attachments, an empty list.
    Exceptions
    ExceptionDescription
    The table or feature class has not been enabled for attachment creation.
    A geodatabase-related exception has occurred.
    Example
    Updating Attachments
      await QueuedTask.Run(() =>
        using (Geodatabase geodatabase = new Geodatabase(new DatabaseConnectionFile(new Uri("path\\to\\sde\\file\\sdefile.sde"))))
        using (FeatureClass landUseCaseFeatureClass = geodatabase.OpenDataset<FeatureClass>("LocalGovernment.GDB.LandUseCase"))
          QueryFilter filter = new QueryFilter { WhereClause = "CASETYPE = 'Rezoning'" };
          using (RowCursor landUseCursor = landUseCaseFeatureClass.Search(filter, false))
            while (landUseCursor.MoveNext())
              using (Feature rezoningUseCase = (Feature)landUseCursor.Current)
                IReadOnlyList<Attachment> rezoningAttachments = rezoningUseCase.GetAttachments();
                IEnumerable<Attachment> filteredAttachments = rezoningAttachments.Where(attachment => !attachment.GetName().Contains("rezoning"));
                foreach (Attachment attachmentToUpdate in filteredAttachments)
                  attachmentToUpdate.SetName(attachmentToUpdate.GetName().Replace(".pdf", "Rezoning.pdf"));
                  rezoningUseCase.UpdateAttachment(attachmentToUpdate);
    Deleting Attachments
        using (Table inspectionTable = geodatabase.OpenDataset<Table>("luCodeInspection"))
          QueryFilter queryFilter = new QueryFilter { WhereClause = "ACTION = '1st Notice'" };
          using (RowCursor cursor = inspectionTable.Search(queryFilter, false))
            while (cursor.MoveNext())
              using (Row currentRow = cursor.Current)
                IReadOnlyList<Attachment> rowAttachments = currentRow.GetAttachments(null, true);
                IEnumerable<Attachment> attachments = rowAttachments.Where(attachment =>
                  attachment.GetContentType().Equals("application/pdf"));
                IReadOnlyList<long> attachmentIDs =
                  attachments.Select(attachment => attachment.GetAttachmentID()) as IReadOnlyList<long>;
                IReadOnlyDictionary<long, Exception> failures = currentRow.DeleteAttachments(attachmentIDs);
                if (failures.Count > 0)
                  //process errors
    Requirements
