ArcGIS.Core.Data Namespace / Row Class / UpdateAttachment Method
An attachment for which all properties have been modified as desired.
Example
    UpdateAttachment Method (Row)
    Updates the properties of an existing attachment fetched using GetAttachment with new values This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Sub UpdateAttachment( _
       ByVal updatedAttachment As Attachment _
    public void UpdateAttachment(
       Attachment updatedAttachment
    Parameters
    updatedAttachment
    Exceptions
    ExceptionDescription
    The table or feature class has not been enabled for attachment creation.
    updatedAttachment is null.
    updatedAttachment's attachment ID is invalid.
    A geodatabase-related exception has occurred.
    Example
    Updating Attachments
      await QueuedTask.Run(() =>
        using (Geodatabase geodatabase = new Geodatabase(new DatabaseConnectionFile(new Uri("path\\to\\sde\\file\\sdefile.sde"))))
        using (FeatureClass landUseCaseFeatureClass = geodatabase.OpenDataset<FeatureClass>("LocalGovernment.GDB.LandUseCase"))
          QueryFilter filter = new QueryFilter { WhereClause = "CASETYPE = 'Rezoning'" };
          using (RowCursor landUseCursor = landUseCaseFeatureClass.Search(filter, false))
            while (landUseCursor.MoveNext())
              using (Feature rezoningUseCase = (Feature)landUseCursor.Current)
                IReadOnlyList<Attachment> rezoningAttachments = rezoningUseCase.GetAttachments();
                IEnumerable<Attachment> filteredAttachments = rezoningAttachments.Where(attachment => !attachment.GetName().Contains("rezoning"));
                foreach (Attachment attachmentToUpdate in filteredAttachments)
                  attachmentToUpdate.SetName(attachmentToUpdate.GetName().Replace(".pdf", "Rezoning.pdf"));
                  rezoningUseCase.UpdateAttachment(attachmentToUpdate);
    Requirements
