ArcGIS.Core.Data Namespace / RowBuffer Class
Members Example
    RowBuffer Class
    Represents a row buffer that can be used with Table.CreateRow
    Syntax
    Public NotInheritable Class RowBuffer
       Inherits ArcGIS.Core.CoreObjectsBase
       Implements System.IDisposable
    public sealed class RowBuffer : ArcGIS.Core.CoreObjectsBase, System.IDisposable
    Remarks
    A row buffer is an in memory representation of the row that can be used to set field values before creating the row in the table. .
    Example
    Creating a Row
      await QueuedTask.Run(() =>
        string message = String.Empty;
        bool creationResult = false;
        EditOperation editOperation = new EditOperation();
        using (Geodatabase geodatabase = new Geodatabase(new DatabaseConnectionFile(new Uri("path\\to\\sde\\file\\sdefile.sde"))))
        using (Table enterpriseTable = geodatabase.OpenDataset<Table>("LocalGovernment.GDB.piCIPCost"))
          // Declare the callback here. We are not executing it .yet.
          editOperation.Callback(context =>
            TableDefinition tableDefinition = enterpriseTable.GetDefinition();
            int assetNameIndex = tableDefinition.FindField("ASSETNA");
            using (RowBuffer rowBuffer = enterpriseTable.CreateRowBuffer())
              // Either the field index or the field name can be used in the indexer.
              rowBuffer[assetNameIndex] = "wMain";
              rowBuffer["COST"] = 700;
              rowBuffer["ACTION"] = "Open Cut";
              // subtype value for "Abandon".
              rowBuffer[tableDefinition.GetSubtypeField()] = 3;
              using (Row row = enterpriseTable.CreateRow(rowBuffer))
                // To Indicate that the attribute table has to be updated.
                context.Invalidate(row);
          }, enterpriseTable);
          try
            creationResult = editOperation.Execute();
            if (!creationResult) message = editOperation.ErrorMessage;
          catch (GeodatabaseException exObj)
            message = exObj.Message;
        if (!string.IsNullOrEmpty(message))
          Debug.WriteLine(message);
    Creating a Feature
        using (FeatureClass enterpriseFeatureClass = geodatabase.OpenDataset<FeatureClass>("LocalGovernment.GDB.FacilitySite"))
          //Declare the callback here. We are not executing it yet
            FeatureClassDefinition facilitySiteDefinition = enterpriseFeatureClass.GetDefinition();
            int facilityIdIndex = facilitySiteDefinition.FindField("FACILITYID");
            using (RowBuffer rowBuffer = enterpriseFeatureClass.CreateRowBuffer())
              rowBuffer[facilityIdIndex] = "wMain";
              rowBuffer["NAME"] = "Griffith Park";
              rowBuffer["OWNTYPE"] = "Municipal";
              rowBuffer["FCODE"] = "Park";
              // Add it to   Attractions Subtype.
              rowBuffer[facilitySiteDefinition.GetSubtypeField()] = 820;
              List<Coordinate2D> newCoordinates = new List<Coordinate2D>
                  new Coordinate2D(1021570, 1880583),
                  new Coordinate2D(1028730, 1880994),
                  new Coordinate2D(1029718, 1875644),
                  new Coordinate2D(1021405, 1875397)
              rowBuffer[facilitySiteDefinition.GetShapeField()] = new PolygonBuilderEx(newCoordinates).ToGeometry();
              using (Feature feature = enterpriseFeatureClass.CreateRow(rowBuffer))
                //To Indicate that the attribute table has to be updated
                context.Invalidate(feature);
          }, enterpriseFeatureClass);
          try
    Inheritance Hierarchy
    System.Object
          ArcGIS.Core.Data.RowBuffer
    Requirements
