Public Property ExecuteMode As ExecuteModeType
public ExecuteModeType ExecuteMode {get; set;}
// Modifies the "NAME" attribute of a specified feature and then splits the feature using the provided polyline, all within a single sequential edit operation. // perform an edit and then a split as one operation. await QueuedTask.Run(() => { var newName = "Modified then Split"; var queryFilter = new QueryFilter() { WhereClause = "OBJECTID = " + objectId.ToString() }; // create an edit operation and name. var op = new EditOperation { Name = "modify followed by split", // set the ExecuteMode ExecuteMode = ExecuteModeType.Sequential }; using (var rowCursor = layer.Search(queryFilter)) { while (rowCursor.MoveNext()) { using var feature = rowCursor.Current as ArcGIS.Core.Data.Feature; op.Modify(feature, "NAME", newName); } } op.Split(layer, objectId, splitLine); if (!op.IsEmpty) { bool result = op.Execute(); } // else // The operation doesn't make any changes to the database so if executed it will fail });
