Public NotInheritable Class Selection Inherits ArcGIS.Core.CoreObjectsBase Implements System.IDisposable
public sealed class Selection : ArcGIS.Core.CoreObjectsBase, System.IDisposable
await QueuedTask.Run(() =>
using (Geodatabase geodatabase = new Geodatabase(new DatabaseConnectionFile(new Uri("path\\to\\sde\\file\\sdefile.sde"))))
using (Table enterpriseTable = geodatabase.OpenDataset<Table>("LocalGovernment.GDB.piCIPCost"))
QueryFilter anotherQueryFilter = new QueryFilter { WhereClause = "FLOOR = 1 AND WING = 'E'" };
// For Selecting all matching entries.
using (Selection anotherSelection = enterpriseTable.Select(anotherQueryFilter, SelectionType.ObjectID, SelectionOption.Normal))
// This can be used to get one record which matches the criteria. No assumptions can be made about which record satisfying the criteria is selected.
using (Selection onlyOneSelection = enterpriseTable.Select(anotherQueryFilter, SelectionType.ObjectID, SelectionOption.OnlyOne))
// This can be used to obtain a empty selection which can be used as a container to combine results from different selections.
using (Selection emptySelection = enterpriseTable.Select(anotherQueryFilter, SelectionType.ObjectID, SelectionOption.Empty))
// If you want to select all the records in a table.
using (Selection allRecordSelection = enterpriseTable.Select(null, SelectionType.ObjectID, SelectionOption.Normal))
System.Object
ArcGIS.Core.Data.Selection
