ArcGIS.Desktop.Layouts Namespace / GraphicFactory Class / CreatePredefinedShapeGraphic Method / CreatePredefinedShapeGraphic(PredefinedShape,Envelope,CIMPolygonSymbol) Method
The shape type of the graphic
The graphic bounding box
The symbol to be used with the graphic (optional)
    Create a polygon graphic of the specified PredefinedShape using the provided bounds and symbol. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Overloads Function CreatePredefinedShapeGraphic( _
       ByVal shapeType As PredefinedShape, _
       ByVal bounds As Envelope, _
       Optional ByVal polySymbol As CIMPolygonSymbol _
    ) As CIMPolygonGraphic
    Parameters
    shapeType
    bounds
    polySymbol
    Return Value
    Exceptions
    ExceptionDescription
    empty or null geometry
    Remarks
    For PredefinedShape.Circle, the height of the resulting bounding box for the graphic will be set equal to the width. For PredefinedShape.RoundedRectangle, a default corner rounding of 20% will be applied.
    Requirements
