ArcGIS.Desktop.Layouts Namespace / MapFrame Class / GetAutoCamera Method
Example
    Gets the auto camera associated with the map frame
    Syntax
    Public Function GetAutoCamera() As CIMAutoCamera
    public CIMAutoCamera GetAutoCamera()
    Return Value
    CIMAutoCamera
    Remarks
    The auto camera is used to set map frame display constraints
    Example
    SetAutoCameraNone
      //Note: Must be on QueuedTask.Run
      var autoCamera = mapFrame.GetAutoCamera();
      autoCamera.Source = AutoCameraSource.None;
      if (mapFrame.ValidateAutoCamera(autoCamera) &&
        !mapFrame.IsMapSeriesMapFrame())
        mapFrame.SetAutoCamera(autoCamera);
    SetAutoCameraFixedExtent
      autoCamera.Source = AutoCameraSource.Fixed;
      autoCamera.AutoCameraType = AutoCameraType.Extent;
      var mf_extent = mapFrame.GetViewExtent();
      var extent = EnvelopeBuilderEx.CreateEnvelope(
        400748.62, 800296.4, 1310669.05, 1424520.74, mapFrame.Map.SpatialReference);
      autoCamera.Extent = extent;
    SetAutoCameraFixedCenter
      //Note: run within the QueuedTask
      autoCamera.AutoCameraType = AutoCameraType.Center;
      var camera = mapFrame.GetMapView(LayoutView.Active).Camera;
      var center = mapFrame.GetViewCenter();
      //var extent = EnvelopeBuilderEx.CreateEnvelope(
      //	400748.62, 800296.4, 1310669.05, 1424520.74, mf.Map.SpatialReference);
      //autoCamera.Extent = extent;
      var camera2 = new CIMViewCamera()
        Heading = 0,
        Pitch = -90,
        Roll = 0,
        Scale = 21169571,
        X = 855708,
        Y = 1112409,
        Z = double.NaN
      autoCamera.Camera = camera2;
      var states = mapFrame.Map.GetLayersAsFlattenedList().First(l => l.Name == "State_Polygons");
      autoCamera.IntersectLayerPath = states.URI;
    SetAutoCameraFixedScale
      autoCamera.AutoCameraType = AutoCameraType.Scale;
        Heading = 0,
        Pitch = -90,
        Roll = 0,
        Scale = 20000571,
        X = 1310669.0 + ((400748.5 - 1310669.0) / 2.0),
        Y = 800296.4 + ((1424520.74 - 800296.4) / 2.0),
        Z = double.NaN
      //autoCamera.IntersectLayerPath = states.URI;
    SetAutoCameraLinkedExtent
      autoCamera.Source = AutoCameraSource.MapFrameLink;
      autoCamera.MapFrameLinkName = "mapFrameLink";
    SetAutoCameraLinkedCenter
    SetAutoCameraLinkedCenterAndScale
      autoCamera.AutoCameraType = AutoCameraType.CenterAndScale;
    SetAutoCameraLinkedScale
    SetAutoCameraLinkedMapSeriesShape
      autoCamera.Source = AutoCameraSource.MapSeriesLink;
      //autoCamera.MapFrameLinkName = mapFrameLink;
    SetAutoCameraLinkedMapSeriesCenter
    SetAutoCameraFixedCenterAndScale
        Heading = 0,
        Pitch = -90,
        Roll = 0,
        Scale = 21169571,
        Z = double.NaN
    Requirements
