Public Sub SetAutoCamera( _ ByVal autoCamera As CIMAutoCamera _ )
public void SetAutoCamera( CIMAutoCamera autoCamera )
Parameters
- autoCamera
- The auto camera to set
| Exception | Description |
| ArcGIS.Core.CalledOnWrongThreadException | This method or property must be called within the lambda passed to QueuedTask.Run. |
| System.InvalidOperationException | Empty map frame |
| System.InvalidOperationException | Map frame contains a scene |
| System.InvalidOperationException | Map frame is linked to a map series |
| System.ArgumentException | Invalid auto camera |
//Note: Must be on QueuedTask.Run
var autoCamera = mapFrame.GetAutoCamera();
autoCamera.Source = AutoCameraSource.None;
if (mapFrame.ValidateAutoCamera(autoCamera) &&
!mapFrame.IsMapSeriesMapFrame())
mapFrame.SetAutoCamera(autoCamera);
autoCamera.Source = AutoCameraSource.Fixed;
autoCamera.AutoCameraType = AutoCameraType.Extent;
var mf_extent = mapFrame.GetViewExtent();
var extent = EnvelopeBuilderEx.CreateEnvelope(
400748.62, 800296.4, 1310669.05, 1424520.74, mapFrame.Map.SpatialReference);
autoCamera.Extent = extent;
//Note: run within the QueuedTask
autoCamera.AutoCameraType = AutoCameraType.Center;
var camera = mapFrame.GetMapView(LayoutView.Active).Camera;
var center = mapFrame.GetViewCenter();
//var extent = EnvelopeBuilderEx.CreateEnvelope(
// 400748.62, 800296.4, 1310669.05, 1424520.74, mf.Map.SpatialReference);
//autoCamera.Extent = extent;
var camera2 = new CIMViewCamera()
Heading = 0,
Pitch = -90,
Roll = 0,
Scale = 21169571,
X = 855708,
Y = 1112409,
Z = double.NaN
autoCamera.Camera = camera2;
var states = mapFrame.Map.GetLayersAsFlattenedList().First(l => l.Name == "State_Polygons");
autoCamera.IntersectLayerPath = states.URI;
autoCamera.AutoCameraType = AutoCameraType.Scale;
Heading = 0,
Pitch = -90,
Roll = 0,
Scale = 20000571,
X = 1310669.0 + ((400748.5 - 1310669.0) / 2.0),
Y = 800296.4 + ((1424520.74 - 800296.4) / 2.0),
Z = double.NaN
//autoCamera.IntersectLayerPath = states.URI;
autoCamera.Source = AutoCameraSource.MapFrameLink;
autoCamera.MapFrameLinkName = "mapFrameLink";
autoCamera.AutoCameraType = AutoCameraType.CenterAndScale;
autoCamera.Source = AutoCameraSource.MapSeriesLink;
//autoCamera.MapFrameLinkName = mapFrameLink;
Heading = 0,
Pitch = -90,
Roll = 0,
Scale = 21169571,
Z = double.NaN
