ArcGIS.Desktop.Layouts Namespace / TextType Enumeration
Example Example
    Specifies the available CIMGraphic text types
    Syntax
    Members
    MemberDescription
    CircleParagraph Circle paragraph text
    EllipseParagraph Ellipse paragraph text
    None None- default
    PointText Point text
    PolygonParagraph Polygon paragraph text
    RectangleParagraph Rectangle paragraph text
    SplinedText Text splined along a line or curve
    Remarks
    Example
    Create Circle Text Graphic
      //Note: Must be on QueuedTask.Run
      //Build geometry
      Coordinate2D center = new Coordinate2D(4.5, 4);
      var eabCir = new EllipticArcBuilderEx(center, 0.5, ArcOrientation.ArcClockwise);
      var cir = eabCir.ToSegment();
      var poly = PolygonBuilderEx.CreatePolygon(
        PolylineBuilderEx.CreatePolyline(cir, AttributeFlags.AllAttributes));
      //Set symbology, create and add element to layout
      CIMTextSymbol sym = SymbolFactory.Instance.ConstructTextSymbol(
        ColorFactory.Instance.GreenRGB, 10, "Arial", "Regular");
      string text = "Circle, circle, circle";
      var graphic = GraphicFactory.Instance.CreateSimpleTextGraphic(
        TextType.CircleParagraph, poly, sym, text);
      //Make an element to add to GraphicsLayer or Layout
      //var ge = ElementFactory.Instance.CreateGraphicElement(layout, graphic,
      //  "New Circle Text", true);
    Create Bezier Graphic
      //Build geometry
      Coordinate2D pt1 = new Coordinate2D(3.5, 7.5);
      Coordinate2D pt2 = new Coordinate2D(4.16, 8);
      Coordinate2D pt3 = new Coordinate2D(4.83, 7.1);
      Coordinate2D pt4 = new Coordinate2D(5.5, 7.5);
      var bez = new CubicBezierBuilderEx(pt1, pt2, pt3, pt4);
      var bezSeg = bez.ToSegment();
      Polyline bezPl = PolylineBuilderEx.CreatePolyline(bezSeg, AttributeFlags.AllAttributes);
            ColorFactory.Instance.BlackRGB, 24, "Comic Sans MS", "Regular");
        TextType.SplinedText, bezPl, sym, "Splined text");
      //var ge = ElementFactory.Instance.CreateGraphicElement(layout, graphic);
    Create Point Text Element 1
      //Create a simple point text element and assign basic symbology and text settings.
      //Build 2D point geometry
      Coordinate2D coord2D = new Coordinate2D(3.5, 10);
                    ColorFactory.Instance.RedRGB, 32, "Arial", "Regular");
      string textString = "Point text";
      //use ElementInfo to set placement properties during create
      var elemInfo = new ElementInfo()
        Anchor = Anchor.CenterPoint,
        Rotation = 45
      var ptTxtElm = ElementFactory.Instance.CreateTextGraphicElement(
        layout, TextType.PointText, coord2D.ToMapPoint(), sym, textString,
                           "New Point Text", true, elemInfo);
      //Change additional text properties
      ptTxtElm.SetX(4.5);
      ptTxtElm.SetY(9.5);
    Create Rectangle Paragraph Text Element 1
      //Create rectangle text with background and border symbology.
      //Build 2D polygon geometry
      List<Coordinate2D> plyCoords = new List<Coordinate2D>();
      plyCoords.Add(new Coordinate2D(3.5, 7));
      plyCoords.Add(new Coordinate2D(4.5, 7));
      plyCoords.Add(new Coordinate2D(4.5, 6.7));
      plyCoords.Add(new Coordinate2D(5.5, 6.7));
      plyCoords.Add(new Coordinate2D(5.5, 6.1));
      plyCoords.Add(new Coordinate2D(3.5, 6.1));
      Polygon poly = PolygonBuilderEx.CreatePolygon(plyCoords);
      //Also notice how formatting tags are using within the text string.
                        ColorFactory.Instance.GreyRGB, 10, "Arial", "Regular");
      string text = "Some Text String that is really long and is " +
                    "<BOL>forced to wrap to other lines</BOL> so that " +
                    "we can see the effects." as String;
      GraphicElement polyTxtElm = ElementFactory.Instance.CreateTextGraphicElement(
        layout, TextType.RectangleParagraph, poly, sym, text, "Polygon Paragraph");
      //(Optionally) Modify paragraph border
      CIMGraphic polyTxtGra = polyTxtElm.GetGraphic();
      CIMParagraphTextGraphic cimPolyTxtGra = polyTxtGra as CIMParagraphTextGraphic;
      cimPolyTxtGra.Frame.BorderSymbol = new CIMSymbolReference();
      cimPolyTxtGra.Frame.BorderSymbol.Symbol =
                   SymbolFactory.Instance.ConstructLineSymbol(
                              ColorFactory.Instance.GreyRGB, 1.0, SimpleLineStyle.Solid);
      polyTxtElm.SetGraphic(polyTxtGra);
    Create Point Text Element 2
      //Build geometry
      var elemInfo = new ElementInfo() { Anchor = Anchor.BottomLeftCorner };
      GraphicElement ptTxtElm = ElementFactory.Instance.CreateTextGraphicElement(
    Create Polygon Paragraph Text Element
      //Build geometry
      string text = "Some text string that is really long and " +
                    "<BOL>wraps to other lines</BOL>" +
                    " so that we can see the effects.";
      var ge = ElementFactory.Instance.CreateTextGraphicElement(
        layout, TextType.PolygonParagraph, poly, sym, text,
              "New Polygon Text", true);
    Create Rectangle Paragraph Text Element 2
      //Build geometry
      Coordinate2D ll = new Coordinate2D(3.5, 4.75);
      Coordinate2D ur = new Coordinate2D(5.5, 5.75);
      Envelope env = EnvelopeBuilderEx.CreateEnvelope(ll, ur);
                 ColorFactory.Instance.WhiteRGB, 10, "Arial", "Regular");
      //(Optionally) Modify border and background with 50% transparency
      //CIMGraphic recTxtGra = recTxtElm.Graphic;
      //CIMParagraphTextGraphic cimRecTxtGra = recTxtGra as CIMParagraphTextGraphic;
      //CIMSymbolReference cimRecTxtBorder = cimRecTxtGra.Frame.BorderSymbol;
      //CIMLineSymbol lineSym = SymbolFactory.Instance.ConstructLineSymbol(
      //                    ColorFactory.Instance.BlackRGB, 1.0, SimpleLineStyle.Solid);
      //cimRecTxtBorder.Symbol = lineSym;
      //CIMSymbolReference cimRecTxtBkgrd = cimRecTxtGra.Frame.BackgroundSymbol;
      //CIMPolygonSymbol polySym = SymbolFactory.Instance.ConstructPolygonSymbol(
      //                            ColorFactory.Instance.GreyRGB, SimpleFillStyle.Solid);
      //CIMColor symCol = polySym.GetColor(IElementContainer container);
      //symCol.SetAlphaValue(50);
      //cimRecTxtBkgrd.Symbol = polySym;
      //recTxtElm.SetGraphic(recTxtGra);
      var ge = ElementFactory.Instance.CreateTextGraphicElement(layout,
                  TextType.RectangleParagraph, env, sym, text, "New Rectangle Text");
    Create Circle Text Element
      //Note: Must be on QueuedTask.Run(() => { ...
      //Build geometry
      GraphicElement cirTxtElm = ElementFactory.Instance.CreateTextGraphicElement(
        layout, TextType.CircleParagraph, poly, sym, text, "New Circle Text", false);
    Create Bezier Text Element
      //Build geometry
        layout, TextType.SplinedText, bezPl, sym, "this is the bezier text",
              "New Bezier Text", true, new ElementInfo() { Anchor = Anchor.CenterPoint });
    Create Ellipse Text Element
      //Build geometry
      Coordinate2D center = new Coordinate2D(4.5, 2.75);
      var eabElp = new EllipticArcBuilderEx(center, 0, 1, 0.45, ArcOrientation.ArcClockwise);
      var ellipse = eabElp.ToSegment();
        PolylineBuilderEx.CreatePolyline(ellipse, AttributeFlags.AllAttributes));
                            ColorFactory.Instance.BlueRGB, 10, "Arial", "Regular");
      string text = "Ellipse, ellipse, ellipse";
      GraphicElement ge = ElementFactory.Instance.CreateTextGraphicElement(
        layout, TextType.PolygonParagraph, poly, sym, text, "New Ellipse Text", false);
    Inheritance Hierarchy
    System.Object
       System.ValueType
          System.Enum
             ArcGIS.Desktop.Layouts.TextType
    Requirements
