ArcGIS.Desktop.Mapping Namespace / IElement Interface
    IElement Interface Methods
    For a list of all members of this type, see IElement members.
    Public Methods
     NameDescription
     Method Convert the element to graphics. This method must be called on the MCT. Use QueuedTask.Run.
     Method Gets the anchor position of the element. This method must be called on the MCT. Use QueuedTask.Run.
     Method Get the element anchor point location. This method must be called on the MCT. Use QueuedTask.Run.
     Method Gets the bounding box for the element. This method must be called on the MCT. Use QueuedTask.Run.
     Method Gets a Custom Property value for the element.
     Method Returns the element's CIM definition. This method must be called on the MCT. Use QueuedTask.Run.
     MethodReturns a Geometry which is a CIM representation of the GraphicElement shape. This method must be called on the MCT. Use QueuedTask.Run.
     Method Gets the height of the element. This method must be called on the MCT. Use QueuedTask.Run.
     Method Gets the locked aspect ratio value of the element. If This method must be called on the MCT. Use QueuedTask.Run.
     Method Gets the parent of this element.
     Method Gets the rotation value for the element. This method must be called on the MCT. Use QueuedTask.Run.
     Method Gets the width of the element. This method must be called on the MCT. Use QueuedTask.Run.
     Method Gets the X position of the element. This method must be called on the MCT. Use QueuedTask.Run.
     Method Gets the Y position of the element. This method must be called on the MCT. Use QueuedTask.Run.
     Method Sets the anchor position of the element. This method must be called on the MCT. Use QueuedTask.Run.
     Method Sets the element anchor point to the X and Y location specified. This method must be called on the MCT. Use QueuedTask.Run.
     Method Sets multiple CustomProperty values for the element. This method must be called on the MCT. Use QueuedTask.Run.
     MethodOverloaded.
     MethodApplies the changes made to a modified CIMElement back to the element on the page layout. This method must be called on the MCT. Use QueuedTask.Run.
     MethodApplies the changes made to a CIMGraphic back to the GraphicElement. This method must be called on the MCT. Use QueuedTask.Run.
     Method Sets the height of the element. This method must be called on the MCT. Use QueuedTask.Run.
     Method Sets the locked state of an element on a page layout. This method must be called on the MCT. Use QueuedTask.Run.
     Method Sets the locked aspect ratio value of the element. This method must be called on the MCT. Use QueuedTask.Run.
     Method Sets the name of the element. This method must be called on the MCT. Use QueuedTask.Run.
     Method Sets the rotation value for the element. This method must be called on the MCT. Use QueuedTask.Run.
     Method Sets the position of an element either at the top or bottom of the layout TOC or a group element. This method must be called on the MCT. Use QueuedTask.Run.
     Method Sets the position of an element either above or below a reference element. This method must be called on the MCT. Use QueuedTask.Run.
     Method Sets the visibility of an element on a page layout. This method must be called on the MCT. Use QueuedTask.Run.
     Method Sets the width of the element. This method must be called on the MCT. Use QueuedTask.Run.
     Method Sets the X position of the element. This method must be called on the MCT. Use QueuedTask.Run.
     Method Sets the Y position of the element. This method must be called on the MCT. Use QueuedTask.Run.
    Top
