ArcGIS.Core.Data Namespace / VersionManager Class / GetHistoricalVersions Method
    Gets a IReadOnlyList of all the available HistoricalVersion in a given enterprise geodatabase. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Function GetHistoricalVersions() As IReadOnlyList(Of HistoricalVersion)
    public IReadOnlyList<HistoricalVersion> GetHistoricalVersions()
    Return Value
    A IReadOnlyList of all the available HistoricalVersion in a given enterprise geodatabase.
    Exceptions
    ExceptionDescription
    A geodatabase-related exception has occurred.
    This method or property must be called within the lambda passed to QueuedTask.Run
    Requirements
