Public NotInheritable Class GDBProjectItem Inherits ArcGIS.Desktop.Internal.Catalog.ProjectItemInfoCrawl Implements ArcGIS.Desktop.Core.IMetadata, ArcGIS.Desktop.Core.IProjectItem, System.ComponentModel.INotifyPropertyChanged
public sealed class GDBProjectItem : ArcGIS.Desktop.Internal.Catalog.ProjectItemInfoCrawl, ArcGIS.Desktop.Core.IMetadata, ArcGIS.Desktop.Core.IProjectItem, System.ComponentModel.INotifyPropertyChanged
A database project item is a file geodatabase, enterprise geodatabase, SQLite database, or a geopackage that has been added to the current project.
// Add a file geodatabase or a SQLite or enterprise database connection to a project
Item gdbToAdd = folderToAdd.GetItems().FirstOrDefault(folderItem => folderItem.Name.Equals("CountyData.gdb"));
// Note: Needs QueuedTask to run
var addedGeodatabase = Project.Current.AddItem(gdbToAdd as IProjectItem);
// use addedGeodatabase;
IEnumerable<GDBProjectItem> newGDBItemsContainer = null;
newGDBItemsContainer = Project.Current.GetItems<GDBProjectItem>();
foreach (var GDBItem in newGDBItemsContainer)
//Do Something with the GDB.
GDBProjectItem gdbProjItem = Project.Current.GetItems<GDBProjectItem>().FirstOrDefault(item => item.Name.Equals("myGDB"));
// Use gdbProjItem;
await QueuedTask.Run(() =>
IEnumerable<GDBProjectItem> gdbProjectItems = Project.Current.GetItems<GDBProjectItem>();
foreach (GDBProjectItem gdbProjectItem in gdbProjectItems)
using (Datastore datastore = gdbProjectItem.GetDatastore())
//Unsupported datastores (non File GDB and non Enterprise GDB) will be of type UnknownDatastore
if (datastore is UnknownDatastore)
continue;
Geodatabase geodatabase = datastore as Geodatabase;
// Use the geodatabase.
System.Object
ArcGIS.Desktop.Framework.Contracts.PropertyChangedBase
ArcGIS.Desktop.Core.Item
ArcGIS.Desktop.Catalog.GDBProjectItem
