ArcGIS.Desktop.Catalog Namespace / ItemDialog Class / Filter Property
Example
    Filter Property (ItemDialog)
    Gets or sets the filter used to restrict the items listed in the Browse dialog box to the subset that is appropriate for a specific task.
    Syntax
    Public Property Filter As String
    public string Filter {get; set;}
    Remarks
    The items available in the Browse dialog box may be filtered to ensure only items appropriate for a specific task are presented. For example, when the Browse dialog box is used to set a tool's parameter, the parameter may require the item to be set to a point feature class or a raster dataset. Items are filtered by specifying a filter or providing the identifier of a browse dialog filter defined in DAML.
    Example
    OpenItemDialog
      // Variables not used in samples
      OpenItemDialog selectItemDialog = new(); // in #region BrowseDialogItems
      // Adds a single item to a map
      OpenItemDialog addToMapDialog = new()
        Title = "Add To Map",
        InitialLocation = @"C:\Data\NewYork\Counties\Erie\Streets",
        Filter = ItemFilters.Composite_AddToMap
    SaveItemDialog
      SaveItemDialog saveLayerFileDialog = new()
        Title = "Save Layer File",
        InitialLocation = @"C:\Data\ProLayers\Geographic\Streets",
        Filter = ItemFilters.Files_All
    Requirements
