ArcGIS.Desktop.Catalog Namespace / ItemFilters Class
Properties
    ItemFilters Class Members
    The following tables list the members exposed by ItemFilters.
    Public Properties
     NameDescription
    Public Propertystatic (Shared in Visual Basic)Supports browsing for annotation feature classes.
    Public Propertystatic (Shared in Visual Basic)Supports browsing BIM files and the feature classes they contain.
    Public Propertystatic (Shared in Visual Basic)Supports browsing CAD datasets and the feature classes they contain.
    Public Propertystatic (Shared in Visual Basic)Supports browsing for items and datasets that can be added to a map. As a composite filter, the default filter allows you to browse for anything that is supported, but focused filters are also available to browse just for layers or geodatabase items, for example, that you want to add to a map.
    Public Propertystatic (Shared in Visual Basic)Supports browsing for items and datasets that can be added to a stereo map. As a composite filter, the default filter allows you to browse for anything that is supported, but focused filters are also available to browse just for layers or geodatabase items, for example, that you want to add to a stereo map.
    Public Propertystatic (Shared in Visual Basic)Supports browsing for web layers and datasets that can be used to define the elevation surface of a globe. As a composite filter, the default filter allows you to browse for anything that is supported, but focused filters are also available to browse just for images services, for example, that you want to define the ground.
    Public Propertystatic (Shared in Visual Basic)Supports browsing for maps and layouts that can be imported to a project. As a composite filter, the default filter allows you to browse for anything that is supported, but focused filters are also available to browse just for ArcGIS Pro map or layout files, for example, that you want to import.
    Public Propertystatic (Shared in Visual Basic)Supports browsing all types of databases supported by ArcGIS Pro. Both database connections in a project and databases stored on a local or network computer can be browsed.
    Public Propertystatic (Shared in Visual Basic)Supports browsing all items or datasets that can be added to a map. This is the default filter in the composite_addToMap filter.
    Public Propertystatic (Shared in Visual Basic)Supports browsing all items or datasets that can be added to a stereo map. This is the default filter in the composite_addToStereoMap filter.
    Public Propertystatic (Shared in Visual Basic)Supports browsing all items that can be imported to a project. This is the default filter in the composite_maps_import filter.
    Public Propertystatic (Shared in Visual Basic)Supports browsing for dimension feature classes.
    Public Propertystatic (Shared in Visual Basic)Supports browsing all types of feature classes.
    Public Propertystatic (Shared in Visual Basic)Supports browsing all types of feature datasets.
    Public Propertystatic (Shared in Visual Basic)Supports browsing for all file extensions.
    Public Propertystatic (Shared in Visual Basic)Supports browsing folder connections in the project and folders on a local or network computer.
    Public Propertystatic (Shared in Visual Basic)Supports browsing all types of items stored in a geodatabase.
    Public Propertystatic (Shared in Visual Basic)Supports browsing all types of geodatabases supported by ArcGIS Pro. Both database connections in a project and databases stored on a local or network computer can be browsed.
    Public Propertystatic (Shared in Visual Basic)Supports browsing Keyhole Markup Language files.
    Public Propertystatic (Shared in Visual Basic)Supports browsing layer files and layer packages available from the active portal and from a local or network computer.
    Public Propertystatic (Shared in Visual Basic)Supports browsing all types of locators, including locator files and ArcGIS Server geocoding services.
    Public Propertystatic (Shared in Visual Basic)Supports browsing maps in the project and all types of maps stored on a local or network computer.
    Public Propertystatic (Shared in Visual Basic)Supports browsing all types of packages available from the active portal and stored on a local or network computer.
    Public Propertystatic (Shared in Visual Basic)Supports browsing project templates available from the active portal and from a local or network computer.
    Public Propertystatic (Shared in Visual Basic)Supports browsing projects and project packages available from the active portal and from a local or network computer.
    Public Propertystatic (Shared in Visual Basic)Supports browsing all types of rasters, including mosaic datasets and file-based raster datasets.
    Public Propertystatic (Shared in Visual Basic)Supports browsing all types of web layers from the active portal and services from server connections in the project that can be added to maps.
    Public Propertystatic (Shared in Visual Basic)Supports browsing all types of web layers from the active portal and services from server connections in the project that can be added to stereo maps.
    Public Propertystatic (Shared in Visual Basic)Supports browsing all types of web layers from the active portal and services from server connections in the project that can be used in ArcGIS Pro.
    Public Propertystatic (Shared in Visual Basic)Supports browsing feature services from the active portal and services from server connections in the project that can be added to maps.
    Public Propertystatic (Shared in Visual Basic)Supports browsing image services from the active portal and services from server connections in the project that can be added to maps.
    Public Propertystatic (Shared in Visual Basic)Supports browsing map services from the active portal and services from server connections in the project that can be added to maps.
    Public Propertystatic (Shared in Visual Basic)Supports browsing for shapefiles stored on a local or network computer.
    Public Propertystatic (Shared in Visual Basic)Supports browsing styles accessed from the active portal or stored on a local or network computer.
    Public Propertystatic (Shared in Visual Basic)Supports browsing all types of tables.
    Public Propertystatic (Shared in Visual Basic)Supports browsing for task files stored on a local or network computer.
    Public Propertystatic (Shared in Visual Basic)Supports browsing all types of text files.
    Public Propertystatic (Shared in Visual Basic)Supports browsing for TIN datasets stored on a local or network computer.
    Public Propertystatic (Shared in Visual Basic)Supports browsing for all types of toolboxes.
    Public Propertystatic (Shared in Visual Basic)Supports browsing for tools stored in toolboxes.
    Public Propertystatic (Shared in Visual Basic)Support browsing for video files.
    Public Propertystatic (Shared in Visual Basic)Supports browsing for all types of workspaces, including folders, geodatabases, and feature datasets.
    Top
