ArcGIS.Desktop.Core Namespace / ItemFactory Class
    ItemFactory Class Methods
    For a list of all members of this type, see ItemFactory members.
    Public Methods
     NameDescription
    Public Method Gets if the dataset for the item can be retrieved.
    Public Method Gets if the definition for the item can be retrieved.
    Public Method Gets if the Knowledge Graph named object type for the item can be retrieved.
    Public MethodCreates a Item representing the resource identified by the Uri
    Public MethodGets the ArcGIS.Core.Data.Dataset associated with the item corresponding to Item.Path. This method must be called on the MCT. Use QueuedTask.Run.
    Public MethodGets the ArcGIS.Core.Data.DatasetType for the item. If the dataset type cannot be determined, then ArcGIS.Core.Data.DatasetType.Unknown is returned.
    Public MethodGets the ArcGIS.Core.Data.Definition associated with the item corresponding to Item.Path. This method must be called on the MCT. Use QueuedTask.Run.
    Public MethodGets the ArcGIS.Core.Data.Knowledge.KnowledgeGraphNamedObjectType associated with the item corresponding to Item.Path. This method must be called on the MCT. Use QueuedTask.Run.
    Public MethodOverloaded.
    Top
