Public Function GetItems(Of T As Item)() As IEnumerable(Of T)
public IEnumerable<T> GetItems<T>() where T: Item
Type Parameters
- T
- The ProjectItem type that is used to filter the complete list of project items
To return all the databases in the project, for example, provide the appropriate project item type. For example, see the GDBProjectItem class in the ArcGIS.Desktop.Catalog namespace.
If a type is not provided, all items that have been added to the current project will be returned, including the maps, layouts, toolboxes, default geodatabase, the home folder connection, and so on. A folder connection is a project item; subfolders and files accessed using a folder connection are items but are not project items because they have not been added to a project.
// not to be included in sample regions
var projectFolderConnection = Project.Current.GetItems<FolderConnectionProjectItem>().First();
// Get all the maps in a project
IEnumerable<MapProjectItem> projectMaps = Project.Current.GetItems<MapProjectItem>();
// Get all the folder connections in a project
IEnumerable<FolderConnectionProjectItem> projectFolders = Project.Current.GetItems<FolderConnectionProjectItem>();
// use projectFolders;
// Get all the server connections in a project
IEnumerable<ServerConnectionProjectItem> projectServers = Project.Current.GetItems<ServerConnectionProjectItem>();
// use projectServers;
// Get all the locator connections in a project
IEnumerable<LocatorsConnectionProjectItem> projectLocators = Project.Current.GetItems<LocatorsConnectionProjectItem>();
// use projectLocators;
// Get all the items that can be accessed from a folder connection. The items immediately
// contained by a folder, that is, the folder's children, are returned including folders
// and individual items that can be used in ArcGIS Pro. This method does not return all
// items contained by any sub-folder that can be accessed from the folder connection.
FolderConnectionProjectItem folderConnection = Project.Current.GetItems<FolderConnectionProjectItem>()
.FirstOrDefault(folder => folder.Name.Equals("Data"));
//Note: Needs QueuedTask to run
IEnumerable<Item> folderContents = folderConnection.GetItems();
FolderConnectionProjectItem projectfolderConnection = Project.Current.GetItems<FolderConnectionProjectItem>().First();
var folderConnectionContent = projectfolderConnection.GetItems();
var folder = folderConnectionContent.FirstOrDefault(folderItem => folderItem.Name.Equals("Tourist Sites"));
var folderContents = folder.GetItems();
//use folderContents;
IEnumerable<Item> allProjectItems = Project.Current.GetItems<Item>();
foreach (var pi in allProjectItems)
//Do Something
var project = Project.Current;
IEnumerable<MapProjectItem> newMapItemsContainer = project.GetItems<MapProjectItem>();
// Note: Needs QueuedTask to run
foreach (var mp in newMapItemsContainer)
//Do Something with the map. For Example:
Map myMap = mp.GetMap();
MapProjectItem mapProjItem = Project.Current.GetItems<MapProjectItem>().FirstOrDefault(item => item.Name.Equals("EuropeMap"));
// Use mapProjItem;
IEnumerable<StyleProjectItem> newStyleItemsContainer = null;
newStyleItemsContainer = Project.Current.GetItems<StyleProjectItem>();
foreach (var styleItem in newStyleItemsContainer)
//Do Something with the style.
var container = Project.Current.GetItems<StyleProjectItem>();
// example: projectStyleName = "ArcGIS 3D";
StyleProjectItem testStyle = container.FirstOrDefault(style => style.Name == projectStyleName);
StyleItem cone = null;
if (testStyle != null)
// example: symbolName = "Cone_Volume_3";
cone = testStyle.LookupItem(StyleItemType.PointSymbol, symbolName);
// Use (testStyle, cone);
var containerStyle = Project.Current.GetProjectItemContainer("Style");
var fav_style_item = containerStyle.GetItems().OfType<StyleProjectItem>().First(item => item.TypeID == "personal_style");
IEnumerable<GDBProjectItem> newGDBItemsContainer = null;
newGDBItemsContainer = Project.Current.GetItems<GDBProjectItem>();
foreach (var GDBItem in newGDBItemsContainer)
//Do Something with the GDB.
GDBProjectItem gdbProjItem = Project.Current.GetItems<GDBProjectItem>().FirstOrDefault(item => item.Name.Equals("myGDB"));
// Use gdbProjItem;
IEnumerable<ServerConnectionProjectItem> newServerConnections = null;
newServerConnections = project.GetItems<ServerConnectionProjectItem>();
foreach (var serverItem in newServerConnections)
//Do Something with the server connection.
ServerConnectionProjectItem serverProjItem = Project.Current.GetItems<ServerConnectionProjectItem>().FirstOrDefault(item => item.Name.Equals("myServer"));
// Use serverProjItem;
//Gets all the folder connections in the current project
var projectFolders = Project.Current.GetItems<FolderConnectionProjectItem>();
foreach (var FolderItem in projectFolders)
//Do Something with the Folder connection.
FolderConnectionProjectItem folderProjItem = Project.Current.GetItems<FolderConnectionProjectItem>().FirstOrDefault(item => item.Name.Equals("myDataFolder"));
// Use folderProjItem;
LayoutProjectItem layoutProjItem = Project.Current.GetItems<LayoutProjectItem>().FirstOrDefault(item => item.Name.Equals("myLayout"));
// Use layoutProjItem;
//Gets all the layouts in the current project
IEnumerable<LayoutProjectItem> projectLayouts = Project.Current.GetItems<LayoutProjectItem>();
foreach (var layoutItem in projectLayouts)
//Do Something with the layout
//Gets a specific GeoprocessingProjectItem in the current project
// example: "myToolbox" is the name of the GeoprocessingProjectItem
GeoprocessingProjectItem gpProjItem = Project.Current.GetItems<GeoprocessingProjectItem>().FirstOrDefault(item => item.Name.Equals("myToolbox"));
// Use gpProjItem;
//Gets all the GeoprocessingProjectItem in the current project
var GPItems = Project.Current.GetItems<GeoprocessingProjectItem>();
foreach (var tbx in GPItems)
//Do Something with the toolbox
List<Item> _mxd = [];
var allFoldersItem = Project.Current.GetItems<FolderConnectionProjectItem>();
if (allFoldersItem != null)
//iterate through all the FolderConnectionProjectItems found
foreach (var folderItem in allFoldersItem)
//Search for mxd files in that folder connection and add it to the List<T>
//Note:ArcGIS Pro automatically creates and dynamically updates a searchable index as you build and work with projects.
//Items are indexed when they are added to a project.
//The first time a folder or database is indexed, indexing may take a while if it contains a large number of items.
//While the index is being created, searches will not return any results.
_mxd.AddRange(folderItem.GetItems());
var contentItem = Project.Current.GetItems<FolderConnectionProjectItem>().First();
//Check if the MCT is required for Refresh()
if (contentItem.IsMainThreadRequired)
contentItem.Refresh();
else
//if item.IsMainThreadRequired returns false, any
//thread can be used to invoke Refresh(), though
//BackgroundTask is preferred.
//Or, via BackgroundTask
ArcGIS.Core.Threading.Tasks.BackgroundTask.Run(() =>
contentItem.Refresh(), ArcGIS.Core.Threading.Tasks.BackgroundProgressor.None);
//Get the catalog pane
IProjectWindow projectWindow = Project.GetCatalogPane();
//or get the active catalog view...
//ArcGIS.Desktop.Core.IProjectWindow projectWindow = Project.GetActiveCatalogWindow();
//eg Find a toolbox in the project
string gpName = "Interacting with Maps.tbx";
var toolbox = Project.Current.GetItems<GeoprocessingProjectItem>().FirstOrDefault(tbx => tbx.Name == gpName);
//Select it under Toolboxes
projectWindow.SelectItemAsync(toolbox, true, true, null);//null selects it in the first container - optionally await
//Note: Project.Current.GetProjectItemContainer("GP") would get toolbox container...
//assume toolbox is also under Folders container. Select it under Folders instead of Toolboxes
var foldersContainer = Project.Current.ProjectItemContainers.First(c => c.Path == "FolderConnection");
//We must specify the container because Folders comes second (after Toolboxes)
projectWindow.SelectItemAsync(toolbox, true, true, foldersContainer);//optionally await
//Find a map and select it
var mapItem = Project.Current.GetItems<MapProjectItem>().FirstOrDefault(m => m.Name == "Map");
//Map only occurs under "Maps" so the container need not be specified
projectWindow.SelectItemAsync(mapItem, true, false, null);
LayoutProjectItem layoutItemByName = Project.Current.GetItems<LayoutProjectItem>()
.FirstOrDefault((lpi) => lpi.Name == "MyLayout");
Layout layoutByName = layoutItemByName.GetLayout();
//Reference layout project items and their associated layout.
//A layout project item is an item that appears in the Layouts
//folder in the Catalog pane.
//Reference all the layout project items
IEnumerable<LayoutProjectItem> layoutProjectItems =
//Or reference a specific layout project item by name
LayoutProjectItem specificLayoutItem = Project.Current.GetItems<LayoutProjectItem>()
.FirstOrDefault(item => item.Name.Equals("MyLayoutItem"));
//Note: Call within QueuedTask.Run()
//Reference a ReportProjectItem in a project by name
ReportProjectItem reportItem = Project.Current.GetItems<ReportProjectItem>().FirstOrDefault(item => item.Name.Equals(reportName));
if (reportItem != null)
//Delete the report from the project
Project.Current.RemoveItem(reportItem);
