ArcGIS.Core.CIM Namespace / CIMDefinition Class
    CIMDefinition Class Properties
    For a list of all members of this type, see CIMDefinition members.
    Public Properties
     NameDescription
    Public Property Gets or sets the metadata URI.
    Public Property Gets or sets the name.
    Public Property Gets or sets the time the source was last modified, as of the last sync. Used to detect when another sync is needed.
    Public Property Gets or sets the source portal URI of the item. Set if sourced from an external item such as an item on a portal.
    Public Property Gets or sets the source URI of the item. Set if sourced from an external item such as an item on a portal.
    Public Property Gets or sets the URI of the definition. Typically set by the system and used as an identifier.
    Public Property Gets or sets a value indicating whether the CIM definition accesses metadata from its data source (the default behavior), or if it has its own metadata stored in the project.
    Top
