ArcGIS.Desktop.Editing.Events Namespace / RowChangedEvent Class
Members Example
    Occurs when a Row is changed.
    Object Model
    RowChangedEvent ClassSubscriptionToken Class
    Syntax
    Public MustInherit NotInheritable Class RowChangedEvent
    public static class RowChangedEvent
    Remarks
    The RowChangedEvent is published during the execution of the edit operation. Any modifications performed within the RowEvent handler can cause cascaded events to be generated. Make sure you have an exit condition to avoid infinite recursion. For example, if you are changing a feature attribute within a RowCreatedEvent or RowChangedEvent, consider tracking that feature's objectID to ignore the corresponding RowChangedEvent your attribute change will generate.
    If you need to edit additional tables within the RowEvent you MUST use the EditOperation that is passed through the RowChangedEventArgs. Do NOT use a new edit operation to create or modify features or rows in your RowEvent callback.
    Example
    Subscribe to Row Events
    // Subscribes to row events for the currently selected feature layer in the active map view.
    await QueuedTask.Run(() =>
      //Listen for row events on a layer
      var featLayer = MapView.Active.GetSelectedLayers()[0] as FeatureLayer;
      var layerTable = featLayer.GetTable();
      //subscribe to row events
      // row created event
      var rowCreateToken = RowCreatedEvent.Subscribe(rowChangedEventArgs => { }, layerTable);
      // row changed event
      var rowChangeToken = RowChangedEvent.Subscribe(rowChangedEventArgs => { }, layerTable);
      // row deleted event
      var rowDeleteToken = RowDeletedEvent.Subscribe(rowChangedEventArgs => { }, layerTable);
    Modify a record within Row Events - using Row.Store
    // Attach an event handler to receive notifications when a row in the selected
    // table is changed. The subscription targets the first <see cref="ArcGIS.Desktop.Mapping.FeatureLayer"/> found in
    // the active map. Use this method to monitor and respond to edits made to table records within the current map
    // context.
    Table thisTable = MapView.Active.Map.GetLayersAsFlattenedList().OfType<FeatureLayer>().FirstOrDefault().GetTable();
        // set the current row changed guid when you execute the Row.Store method
        // used for re-entry checking
        Guid _currentRowChangedGuid = new();
        // RowEvent callbacks are always called on the QueuedTask so there is no need
        // to wrap your code within a QueuedTask.Run lambda.
        var row = rowChangedEventArgs.Row;
        // check for re-entry  (only if row.Store is called)
        if (_currentRowChangedGuid == rowChangedEventArgs.Guid)
          return;
        var fldIdx = row.FindField("POLICE_DISTRICT");
        if (fldIdx != -1)
          //Validate any change to �police district�
          //   cancel the edit if validation on the field fails
          if (row.HasValueChanged(fldIdx))
            // cancel edit with invalid district (5)
            var value = row["POLICE_DISTRICT"].ToString();
            if (value == "5")
              //Cancel edits with invalid �police district� values
              rowChangedEventArgs.CancelEdit($"Police district {row["POLICE_DISTRICT"]} is invalid");
          // update the description field
          row["Description"] = "Row Changed";
          //  this update with cause another OnRowChanged event to occur
          //  keep track of the row guid to avoid recursion
          _currentRowChangedGuid = rowChangedEventArgs.Guid;
          row.Store();
          _currentRowChangedGuid = Guid.Empty;
      }, thisTable);
    Modify a record within Row Events - using EditOperation.Modify
    // Subscribe to the <see cref="ArcGIS.Desktop.Editing.Events.RowChangedEvent"/> for
    // the first  <see cref="ArcGIS.Desktop.Mapping.FeatureLayer"/> in the active map. The event handler can be used to
    // respond to changes in rows within the table, such as modifications or updates.
    Table changeTable = MapView.Active.Map.GetLayersAsFlattenedList().OfType<FeatureLayer>().FirstOrDefault().GetTable();
        // set the last row changed guid when you execute the Row.Store method
        Guid _lastEdit = new();
        //example of modifying a field on a row that has been created
        var parentEditOp = rowChangedEventArgs.Operation;
        // avoid recursion
        if (_lastEdit != rowChangedEventArgs.Guid)
          //update field on change
          parentEditOp.Modify(rowChangedEventArgs.Row, "ZONING", "New");
          _lastEdit = rowChangedEventArgs.Guid;
      }, changeTable);
    Determine if Geometry Changed while editing
    // Set up a listener for row change events on the table associated with the
    // provided feature layer. The event subscription occurs within a queued task to ensure thread safety.
       //Listen to the RowChangedEvent that occurs when a Row is changed.
       var modifiedFeatureLayer = MapView.Active.Map.GetLayersAsFlattenedList().OfType<FeatureLayer>().FirstOrDefault(); ;
           //Get the layer's definition
           var lyrDefn = modifiedFeatureLayer.GetFeatureClass().GetDefinition();
           //Get the shape field of the feature class
           string shapeField = lyrDefn.GetShapeField();
           //Index of the shape field
           var shapeIndex = lyrDefn.FindField(shapeField);
           //Original geometry of the modified row
           var geomOrig = rowChangedEventArgs.Row.GetOriginalValue(shapeIndex) as Geometry;
           //New geometry of the modified row
           var geomNew = rowChangedEventArgs.Row[shapeIndex] as Geometry;
           //Compare the two
           bool shapeChanged = geomOrig.IsEqual(geomNew);
           if (shapeChanged)
             // The geometry has not changed
             Console.WriteLine("Geometry has not changed");
           else
             // The geometry has changed
             Console.WriteLine("Geometry has changed");
         }, modifiedFeatureLayer.GetTable());
    Inheritance Hierarchy
    System.Object
    Requirements
