ArcGIS.Desktop.Editing.Events Namespace / RowCreatedEvent Class
Members Example
    Occurs when a Row is created.
    Object Model
    RowCreatedEvent ClassSubscriptionToken Class
    Syntax
    Public MustInherit NotInheritable Class RowCreatedEvent
    public static class RowCreatedEvent
    Remarks
    The RowCreatedEvent is published during the execution of the edit operation. Any modifications performed within the RowEvent handler can cause cascaded events to be generated. Make sure you have an exit condition to avoid infinite recursion. For example, if you are changing a feature attribute within a RowCreatedEvent or RowChangedEvent, consider tracking that feature's objectID to ignore the corresponding RowChangedEvent your attribute change will generate.
    If you need to edit additional tables within the RowEvent you MUST use the ArcGIS.Core.Data API to edit the tables directly. Do NOT use a new edit operation to create or modify features or rows in your RowEvent callback.
    Example
    Subscribe to Row Events
    // Subscribes to row events for the currently selected feature layer in the active map view.
    await QueuedTask.Run(() =>
      //Listen for row events on a layer
      var featLayer = MapView.Active.GetSelectedLayers()[0] as FeatureLayer;
      var layerTable = featLayer.GetTable();
      //subscribe to row events
      // row created event
      var rowCreateToken = RowCreatedEvent.Subscribe(rowChangedEventArgs => { }, layerTable);
      // row changed event
      var rowChangeToken = RowChangedEvent.Subscribe(rowChangedEventArgs => { }, layerTable);
      // row deleted event
      var rowDeleteToken = RowDeletedEvent.Subscribe(rowChangedEventArgs => { }, layerTable);
    Create a record in a separate table in the Map within Row Events
    // attach an event handler to receive notifications when a new row is created in the
    // associated table of the first feature layer found in the active map. Use this method to enable custom logic in
    // response to row creation events within your ArcGIS Pro add-in.
    // subscribe to the RowCreatedEvent
    Table table = MapView.Active.Map.GetLayersAsFlattenedList().OfType<FeatureLayer>().FirstOrDefault().GetTable();
        // RowEvent callbacks are always called on the QueuedTask so there is no need
        // to wrap your code within a QueuedTask.Run lambda.
        // get the edit operation
        var parentEditOp = rowChangedEventArgs.Operation;
        // set up some attributes
        var attribs = new Dictionary<string, object>
          { "Layer", "Parcels" },
          { "Description", "objectId: " + rowChangedEventArgs.Row.GetObjectID().ToString() + " " + DateTime.Now.ToShortTimeString() }
        //create a record in an audit table
        var sTable = MapView.Active.Map.FindStandaloneTables("EditHistory")[0];
        var table = sTable.GetTable();
        parentEditOp.Create(table, attribs);
      }, table);
    Create a record in a separate table within Row Events
    // Attach an event handler to the <see cref="ArcGIS.Desktop.Editing.Events.RowCreatedEvent"/> for the table associated with the first <see cref="ArcGIS.Desktop.Mapping.FeatureLayer"/> in the active map. Use this method to monitor when new rows are created
    // in that table, enabling custom logic to be executed in response to record creation events.
    Table firstTable = MapView.Active.Map.GetLayersAsFlattenedList().OfType<FeatureLayer>().FirstOrDefault().GetTable();
      // update a separate table not in the map when a row is created
      // You MUST use the ArcGIS.Core.Data API to edit the table. Do NOT
      // use a new edit operation in the RowEvent callbacks
      try
        // update Notes table with information about the new feature
        using var geoDatabase = new Geodatabase(new FileGeodatabaseConnectionPath(new Uri(Project.Current.DefaultGeodatabasePath)));
        using var table = geoDatabase.OpenDataset<Table>("Notes");
      catch (Exception e)
        throw new Exception($@"Error in OnRowCreated for objectId: {rowChangedEventArgs.Row.GetObjectID()} : {e}");
    }, firstTable);
    Inheritance Hierarchy
    System.Object
    Requirements
