Public MustInherit NotInheritable Class RowDeletedEvent
public static class RowDeletedEvent
If you need to edit additional tables within the RowEvent you MUST use the ArcGIS.Core.Data API to edit the tables directly. Do NOT use a new edit operation to create or modify features or rows in your RowEvent callback.
// Subscribes to row events for the currently selected feature layer in the active map view. await QueuedTask.Run(() => { //Listen for row events on a layer var featLayer = MapView.Active.GetSelectedLayers()[0] as FeatureLayer; var layerTable = featLayer.GetTable(); //subscribe to row events // row created event var rowCreateToken = RowCreatedEvent.Subscribe(rowChangedEventArgs => { }, layerTable); // row changed event var rowChangeToken = RowChangedEvent.Subscribe(rowChangedEventArgs => { }, layerTable); // row deleted event var rowDeleteToken = RowDeletedEvent.Subscribe(rowChangedEventArgs => { }, layerTable); });
// Subscribe to the <see cref="ArcGIS.Desktop.Editing.Events.RowDeletedEvent"/> for the first feature layer's table in the active map. The event handler can be used to intercept and handle row deletion events, such as canceling a delete operation if certain conditions are met. // subscribe to the RowDeletedEvent for the appropriate table // in preparation for the event: public static Guid _currentRowDeletedGuid = Guid.Empty; Table cancelDeleteTable = MapView.Active.Map.GetLayersAsFlattenedList().OfType<FeatureLayer>().FirstOrDefault().GetTable(); RowDeletedEvent.Subscribe(rowChangedEventArgs => { // RowEvent callbacks are always called on the QueuedTask so there is no need // to wrap your code within a QueuedTask.Run lambda. var row = rowChangedEventArgs.Row; // check for re-entry if (_currentRowDeletedGuid == rowChangedEventArgs.Guid) return; // cancel the delete if the feature is in Police District 5 var fldIdx = row.FindField("POLICE_DISTRICT"); if (fldIdx != -1) { var value = row[fldIdx].ToString(); if (value == "5") { //cancel with dialog // Note - feature edits on Hosted and Standard Feature Services cannot be cancelled. rowChangedEventArgs.CancelEdit("Delete Event\nAre you sure", true); // or cancel without a dialog // args.CancelEdit(); } } _currentRowDeletedGuid = rowChangedEventArgs.Guid; }, cancelDeleteTable);
System.Object
