ArcGIS.Desktop.Editing.Templates Namespace / EditingTemplate Class
    EditingTemplate Class Properties
    For a list of all members of this type, see EditingTemplate members.
    Public Properties
     NameDescription
    Public Property Gets whether this EditingTemplate can be included as part of a GroupTemplate.
    Public Propertystatic (Shared in Visual Basic)Gets the currently active EditingTemplate.
    Public Property Gets the DAML ID of the Tool that is currently chosen as this EditingTemplate's DefaultTool.
    Public Property Gets the description of this EditingTemplate.
    Public Property Gets whether the application's current tool is the last selected Tool for this EditingTemplate.
    Public Property Gets the Inspector that contains the Attributes associated with this EditingTemplate.
    Public Property Gets whether this EditingTemplate is currently being used and its last selected Tool is currently the active Tool.
    Public Property Gets whether this EditingTemplate is the template currently being used.
    Public Property Gets the DAML ID of the Tool that was most recently selected when using this EditingTemplate.
    Public Property Gets the Layer that is associated with this EditingTemplate.
    Public PropertyGets the Map that contains the associated MapMember.
    Public Property Gets the MapMember that is associated with this EditingTemplate.
    Public Property Gets the name of this EditingTemplate.
    Public Property Gets whether this EditingTemplate's Attributes pass the MapMember's DefinitionQuery.
    Public Property Gets the the tool daml ids that are registered to the template (template type, template geometry type etc). ie the set that displays in Template Properties.
    Public Property Gets the StandaloneTable that is associated with this EditingTemplate.
    Public Property Gets the collection of Tags that help to make this EditingTemplate searchable.
    Public Property Gets a collection of DAML IDs for each of the Tools that are available for use with this EditingTemplate.
    Top
