ArcGIS.Desktop.Editing.Templates Namespace / EditingTemplate Class / ActivateDefaultToolAsync Method
Example
    Activates the Tool that is identified by DefaultToolID.
    Syntax
    Public Function ActivateDefaultToolAsync() As Task
    public Task ActivateDefaultToolAsync()
    Exceptions
    ExceptionDescription
    Template must be on the active map
    Example
    Activate template and its default editing tool
    await QueuedTask.Run(() =>
      // Get all templates for the layer
      var templates = featureLayer.GetTemplates();
      if (templates.Count == 0)
        return;
      // Get the first template - alternatively get a specific template
      var template = templates.First();
      // Activate the default tool
      template.ActivateDefaultToolAsync();
    Hide or show editing tools on templates
         //hide all tools except line tool on a given feature layer
         var editTemplates = featureLayer.GetTemplates();
         var newCIMEditingTemplates = new List<CIMEditingTemplate>();
         foreach (var et in editTemplates)
           //initialize template by activating default tool
           et.ActivateDefaultToolAsync();
           var cimEditTemplate = et.GetDefinition();
           //get the visible tools on this template
           var allTools = et.ToolIDs.ToList();
           //add the hidden tools on this template
           allTools.AddRange(cimEditTemplate.GetExcludedToolIDs().ToList());
           //hide all the tools then allow the line tool
           cimEditTemplate.SetExcludedToolIDs(allTools.ToArray());
           cimEditTemplate.AllowToolID("esri_editing_SketchLineTool");
           newCIMEditingTemplates.Add(cimEditTemplate);
         //update the layer templates
         var layerDef = featureLayer.GetDefinition() as CIMFeatureLayer;
         // Set AutoGenerateFeatureTemplates to false for template changes to stick
         layerDef.AutoGenerateFeatureTemplates = false;
         layerDef.FeatureTemplates = newCIMEditingTemplates.ToArray();
         featureLayer.SetDefinition(layerDef);
    Requirements
