Copy feature datasets, feature classes, and tables to a geodatabase
You can copy or move datasets in the following ways:
  • Use context menu commands, keyboard shortcuts, or drag and drop when working in the Catalog pane or Catalog view. To learn more, see Copy and move items.
  • Use geoprocessing tools, such as the Copy tool in the Data Management Tools toolbox. This tool works the same way as the Copy command in the Catalog pane, copying input data from one location and pasting it to another location.
You can copy entire feature datasets or individual feature classes and tables. For every feature dataset, feature class, and table you copy and paste, the result is a new feature dataset, feature class, and table in the destination geodatabase with all the features or records from the source data. If you’re copying into a file or enterprise geodatabase, you can specify a configuration keyword to control how the new feature classes and tables are stored.
When you copy and paste datasets between geodatabases, dependent geodatabase objects are typically copied automatically to maintain dataset behavior and integrity. Common examples include:
  • Domains, subtypes, and indexes
  • Participating topology feature classes
  • Relationship classes and related tables or feature classes
  • Feature-linked annotation
  • Attribute rules and referenced datasets or database sequences
  • Utility networks or trace networks and their associated feature classes
Important:
If you are copying a feature class into an existing feature dataset, either in the same geodatabase or in another geodatabase, the spatial reference of the feature class and feature dataset must match. If they do not, you cannot paste the feature class into the feature dataset.
You can copy any dataset from a geodatabase or database using the Copy command on the context menu in the Catalog pane, and paste the dataset into a destination geodatabase. There are two options when pasting the datasets into the destination geodatabase: Paste and Paste Special.
Paste
To copy and paste tables, feature classes, or feature datasets in the Catalog pane using the Paste command , follow these steps:
  1. In the Catalog pane, connect to the geodatabase or database that contains the feature dataset, feature class, or table you want to copy.
  2. Right-click the feature dataset, feature class, or table and click Copy .
  3. Right-click the geodatabase to which you want to copy the data.
  4. Click Paste .
    A progress bar appears in the destination geodatabase to display the progress of the copy-paste operation. You can cancel the copy-paste operation by clicking the stop button in the progress bar.
    A copy of the feature dataset, feature class, or table and its related items are present in the target geodatabase. If there are any name conflicts in the target geodatabase, the name of the copied data has a number appended to the end of its name to make the name unique.
Paste Special
To have more control over how the data is pasted into the target geodatabase, you can choose the Paste Special option on the context menu. The Paste Special dialog box lists the datasets being pasted into the target geodatabase. Any name conflicts are automatically resolved and highlighted in red. To rename an item that is being copied, you can do so by editing the Target Name parameter. If you are pasting into a file or enterprise geodatabase and you want to control how the new feature classes and tables are created and stored, you can choose a configuration keyword from the Configuration Keyword drop-down list. Attribute domains that are associated with the datasets being copied are also listed on this dialog box but are for informative purposes only, meaning, for example, that you cannot rename the output domain name.
The Paste Special option is only available on the context menu for geodatabases that have been added to the project.
  2. Right-click the feature dataset, feature class, or table you want to copy and click Copy .
  4. Click Paste Special .
    The Paste Special dialog box appears, showing what data is being copied. Any name conflicts are automatically resolved and highlighted in red.
  5. Type over the default names in the Target Name text box to change any of the output names.
  6. If you’re copying into a file or enterprise geodatabase and want to control how the new feature classes and tables are created and stored, choose a keyword from the drop-down list.
  7. Click OK to paste the data into the target geodatabase.
    A progress bar appears in the target geodatabase to display the progress of the copy-paste operation. You can cancel the copy-paste operation by clicking the stop button in the progress bar.
    A copy of the feature dataset, feature class, or table and its related items are present in the destination geodatabase.
Copy features using Export
You can export the features in a layer to a new feature class by using the Copy Features geoprocessing tool that opens when you select Export Features from the layer context menu in the Contents pane.
  1. Add a layer to the map.
  2. Right-click the layer in the Contents pane and click Data > Export features.
    If there are features selected in the map, the Copy Features tool copies only the selected features. To include all features in the feature class, clear the selection before you export the features.
    The Copy Features geoprocessing tool opens. The Input Features parameter is populated with the layer you selected.
  3. Choose a destination geodatabase and feature class name for the Output Feature Class parameter.
  4. Click Run to run the tool and make a copy of the features in the layer.
Copy multiple feature classes
You can use the Feature Class To Geodatabase geoprocessing tool to export one or more feature classes from one geodatabase to another.
Be aware that the Feature Class To Geodatabase tool copies only simple feature classes. For example, if you have feature classes contained within feature datasets to be exported, only the feature classes are copied. The feature dataset, plus any of its advanced elements, such as topologies, relationship classes, or attachments, will not be copied to the output geodatabase.
  1. Open the Feature Class To Geodatabase geoprocessing tool. You can do this by searching for it in the Geoprocessing pane search, or by browsing to it in the Conversion toolbox in the To Geodatabase toolset.
  2. Add feature classes to the Input Features parameter by clicking the Browse button and choosing the feature classes you want. Alternatively, if you have the feature classes open as a layer in the map, use the drop-down menu in the Input Features parameter and select the layer you want to copy.
  3. Use the Browse button for the Output Geodatabase parameter to choose the output geodatabase into which you want to copy your feature classes.
  4. Click Run to run the tool.
Tip:
You can use a similar workflow to copy multiple tables from one geodatabase to another by using the Table To Geodatabase geoprocessing tool.
