Get started with ArcGIS Linear Referencing
ArcGIS Linear Referencing provides capabilities to manage and locate assets, characteristics, and other data in multiple industries.
Important:
In ArcGIS Pro 3.8, ArcGIS Pipeline Referencing and ArcGIS Roads and Highways were consolidated into a new extension called ArcGIS Linear Referencing. This extension provides the advanced linear referencing capabilities previously available through ArcGIS Location Referencing.
The tools previously on the Location Referencing tab are available on the Linear Referencing tab.
ArcGIS Linear Referencing includes two options:
The ArcGIS Linear Referencing extension, which requires an extension license and provides advanced enterprise capabilities.
Basic linear referencing, which does not require an extension license and supports creating and managing basic linear referencing datasets.
Basic linear referencing supports creating and managing basic linear referencing datasets.
Learn more about the Basic toolset in the Linear Referencing toolbox
The ArcGIS Linear Referencing extension provides a linear referencing system (LRS) that supports the following:
LRS data model
Route and event loading tools
Route editing
Event editing
Geoprocessing tools
Web services
Learn more about authorizing and managing extension licenses in ArcGIS Pro
The following sections describe the capabilities supported by the ArcGIS Linear Referencing extension.
LRS data model
To use the ArcGIS Linear Referencing extension, you must have your data in the LRS data model. ArcGIS Linear Referencing provides the ability to edit and maintain LRS Networks and associated event data. It also supports updating event measures and route associations based on changes to an LRS Network.
Utility and Pipeline Data Model (UPDM)
The Utility and Pipeline Data Model (UPDM) includes predefined feature classes for events and features in the pipeline network. The UPDM incorporates the LRS data model.
You can create the UPDM schema in a file geodatabase and load all the required data. Once the data is loaded, you can migrate your LRS to an enterprise geodatabase. You also have the flexibility to define your own events data model or use the UPDM.
You can model your own LRS geodatabase using the UPDM or an out-of-the-box data model that requires you to create an LRS, create LRS events, and load event data using the Append Events tool.
Modeling an LRS geodatabase is an involved process and requires experience.
Learn more about managing ArcGIS Linear Referencing and a Utility Network together
LRS route and event loading
You can manage the modeling, creation, and configuration of the LRS, networks, and events, including route and event loading, in ArcGIS Pro using geoprocessing tools.
Learn more about creating the LRS, networks, and events
ArcGIS Linear Referencing supports multiple linear referencing methods (LRM). The data model supports combining event data from different linear referencing methods. It also supports translating event data from one LRM to another.
LRS route editing
To edit routes in an LRS Network, you must use the tools on the Linear Referencing tab. This tab supports editing the LRS data model elements used to create an LRS Network. On this tab, you can create a route, realign a route, reassign a route, retire a route, extend a route, and cartographically realign routes.
You can also edit calibration points and centerlines. The Linear Referencing tab is context based and is available only when you have LRS data added to a map.
LRS features (routes, events, calibration points, and intersections) are time-aware. If you are configuring maps for route editing, it is recommended that you configure time support for each of these layers in the map.
LRS event editing
ArcGIS Linear Referencing supports adding and editing events through ArcGIS Pro and ArcGIS Experience Builder.
Refer to the following topics to learn more about adding and editing events in ArcGIS Pro:
Experience Builder in ArcGIS Enterprise includes a suite of Linear Referencing widgets and templates that support visualizing, querying, and editing LRS data.
Learn more about using Experience Builder and deploying Linear Referencing widgets
Event behaviors
ArcGIS Linear Referencing supports updating event measures and route associations based on changes to the LRS Network.
Learn more about event behaviors
Geoprocessing tools
The Linear Referencing toolbox contains a series of tools for creating, calibrating, displaying, and configuring the data used for linear referencing.
Platform for reporting
ArcGIS Linear Referencing spatially enables event data from non-GIS systems and integrates it with the LRS.
For GIS professionals in the pipeline industry, ArcGIS Linear Referencing can be used to generate data products and maps that support annual Pipeline and Hazardous Materials Safety Administration (PHMSA), mileage, and other ad hoc reporting.
For GIS professionals in the transportation industry, ArcGIS Linear Referencing can be used to generate data products and maps that support safety analysis, traffic congestion analysis, infrastructure maintenance planning, and other roadway data analyses. These reports and data products can provide government and public entities transparency into many facets of highway-based data, such as highway assets, incidents, and roadway characteristics.
LRS web services
ArcGIS Linear Referencing extends the ArcGIS Server map service to provide linear referencing capability to your data as REST services. These capabilities include the following:
Editing events
Translating coordinates to measures
Translating measures to coordinates
Translating between measure systems
Dynamically segmenting event layers
Detecting gaps, overlaps, and invalid measures on events
For more information about services and developing for services, refer to the following:
