Language:              C#
Subject:               OCR
Contributor:           ArcGIS Pro SDK Team <arcgisprosdk@esri.com>
Organization:          Esri, http://www.esri.com
Date:                  10/19/2026
ArcGIS Pro:            3.8
IDE:                   Visual Studio 2026, Visual Studio Code
OCR
Determine if a document is valid for OCR
string docFileName1 = "c:\\MyData\\MyDocument.pdf";
  string docFileName2 = "c:\\MyData\\MyDocument.bmp";
  string docFileName3 = "c:\\MyData\\MyDocument.txt";
  var isValid = OCRManager.Instance.IsValidDocumentForOCR(docFileName1);
  // isValid = true
  isValid = OCRManager.Instance.IsValidDocumentForOCR(docFileName2);
  // isValid = true
  isValid = OCRManager.Instance.IsValidDocumentForOCR(docFileName3);
  // isValid = false
Get number of pages in a document
string docFileName = "c:\\MyData\\MyDocument.pdf";
  var pageCount = OCRManager.Instance.GetDocumentPageCount(docFileName);
Extract text from a document
  var text = await OCRManager.Instance.ExtractTextFromDocumentAsync(docFileName);
  // or extract from a specific page
  //int pageIdx = 1;
  //var text = await OCRManager.Instance.ExtractTextFromDocumentAsync(deedFileName, pageIdx);
Extract text from a document using a CancellationTracker
  var text = "";
  bool canceled = false;
  using (CancelableProgressorSource cps = new CancelableProgressorSource("Reading document", "Canceled"))
    canceled = await QueuedTask.Run<bool>(async () =>
      try
        text = await ArcGIS.Core.OCR.OCRManager.Instance.ExtractTextFromDocumentAsync(docFileName, cps.Progressor.CancellationToken);
      catch (OperationCanceledException cex)
        return true;
      catch (Exception ex)
      return false;
    }, cps.Progressor);
  if (canceled)
    // to do - some cancel action
  else
    // to do - something with text
Extract text from a document using OCROptions
string docFileName = "c:\\MyData\\MyDocument.tiff";
  var ocrOptions = new OCROptions(docFileName);
  ocrOptions.OutputType = OCROutputType.Text;
  // set a specific page if necessary
  // (if not set, then all pages are scanned)
  // ocrOptions.Page = pageIdx;
  // set the resolution if necessary
  // ocrOptions.Resolution = 400;
  var output = await OCRManager.Instance.ExtractFromDocumentAsync(ocrOptions);
  var textOutput = output as OCRTextOutput;
  var text = textOutput.Text;
Extract text from a document using a different model
string docFileName = "c:\\MyData\\MyDocument.jpg";
  // set the language
  // (de.traineddata should be installed at (arcgis_install_folder)\Resources\OCR)
  // if file cannot be found an exception is thrown
  ocrOptions.Model = "de";
  try
  catch (ArcGIS.Core.OCR.Exceptions.OCRException ex)
Extract TSV output from a document
string docFileName = "c:\\MyData\\MyDocument.bmp";
  ocrOptions.OutputType = OCROutputType.TSV;
  if (output is OCRTSVOutput ocr_tsvOutput)
    // process the tsv output
    foreach (var page in ocr_tsvOutput.Pages)
      foreach (var block in page.Blocks)
        foreach (var para in block.Paragraphs)
          foreach (var line in para.Lines)
            foreach (var word in line.Words)
              var content = word.Content;
              var confidence = word.Confidence;
              // process content according to confidence
Get text from TSVOutput (simple)
string text = "";
  var flowDocument = new FlowDocument();
  foreach (var page in tsvOutput.Pages)
    List<Paragraph> pageParagraphs = new();
      foreach (var paragraph in block.Paragraphs)
        foreach (var line in paragraph.Lines)
          string lineWords = string.Join(" ", line.Words.Select(w => w.Content));
          pageParagraphs.Add(new Paragraph(new Span(new Run(lineWords))));
    flowDocument.Blocks.AddRange(pageParagraphs);
    flowDocument.Blocks.Add(new Paragraph(new Span(new Run(Environment.NewLine))));
  var startPointer = flowDocument?.ContentStart;
  var endPointer = flowDocument?.ContentEnd;
  if (startPointer != null && endPointer != null)
    text = new TextRange(startPointer, endPointer).Text;
