ContingentFieldValue
Summary
The ContingentFieldValue object contains properties that describe the properties of the field used for a contingent value.
Discussion
ContingentFieldValue objects cannot be created directly. ContingentFieldValue properties can be accessed through the values object that is returned by the arcpy.da.ListContingentValues function.
Properties
| Name | Explanation | Data type |
code (Read only) |
If the contingent value uses a coded value domain, this property returns the code that is used for the contingent value. |
Long |
name (Read only) |
The name of the field that participates in the field group. |
String |
range (Read only) |
If the contingent value uses a range domain, this property returns the minimum and maximum values of the range for the contingent value. |
Long |
type (Read only) |
Specifies the type of field value used for the contingent value.
String |
