Add toolboxes in Python
ArcPy is initially only aware of tools stored in ArcGIS system toolboxes. Custom tools created by an individual, third party, or organization and stored in a custom toolbox can be accessed in ArcPy like any system tool by importing the custom toolbox.
In the following example, the ImportToolbox function is used to allow tools contained in a custom toolbox to be accessed in ArcPy. After importing the toolbox, the custom tools can be accessed as arcpy.<toolname>_<alias>.
>>> arcpy.ImportToolbox("c:/mytools/geometrytools.atbx")
>>> arcpy.CreateRegularPolygons_geometry(
When a tool is accessed through the ArcPy site package, the toolbox alias where the tool is contained is a required suffix (arcpy.<toolname>_<alias>). Since ArcPy depends on toolbox aliases to access and run the correct tool, aliases are extremely important when importing custom toolboxes. A good practice is to always define a custom toolbox's alias. However, if the toolbox alias is not defined, a temporary alias can be set as the second parameter of the ImportToolbox function.
>>> arcpy.ImportToolbox("c:/mytools/geometrytools.atbx", "mytools")
>>> arcpy.CreateRegularPolygons_mytools(
Server toolboxes
Geoprocessing services can also be added to the scripting environment using ImportToolbox. Whether adding the geoprocessing service from a local or internet server, the server and toolbox name are semicolon delimited.
To add a toolbox from a Internet server, provide the url and toolbox name delimited by a semi-colon.
import arcpy
arcpy.ImportToolbox("http://lab13/arcgis/services;BufferByVal")
To add a toolbox from a local server, provide the server and toolbox name delimited by a semi-colon.
import arcpy
arcpy.ImportToolbox("lab13;BufferByVal")
