PixelBlock
Summary
Defines a group or block of pixels to include for raster processing. The PixelBlockCollection object is made up of one or more PixelBlock objects.
Discussion
The PixelBlock object defines a block of pixels within a raster to use for processing. It is used in conjunction with the PixelBlockCollection object to iterate through one or more large rasters for processing.
Syntax
PixelBlock(data, extent)
Name Explanation Data type
data
A NumPy array containing the pixel values for the pixel block.
If the raster is not multidimensional, the shape of the array should be (rows, columns, bands).
If the raster is multidimensional, the shape of the array should be (slices, rows, columns, bands).
NumPyArray
extent
The spatial extent of the pixel block.
Extent
Properties
cell_size
(Read only)
The cell size of the pixels in the pixel block. This is a tuple containing the cell size in the x-direction and the y-direction (x-size, y-size).
tuple
tlc
(Read only)
The coordinates of the pixel block's upper left corner.
Point
spatial_reference
(Read only)
The spatial reference of the exported image. Supported options include the following:
  • None
  • SpatialReference data type
  • ICS or ICS:<object_id>, where object_id selects the specific raster whose image coordinate system should be used.
If a value is not specified, the spatial reference of the raster dataset is used.
SpatialReference
Methods
getData()
Returns the NumPy array within the pixel block.
Return value
Data type Explanation
NumPyArray
The NumPy array object from the pixel block.
Code sample
PixelBlock example
Iterates through pixel blocks to calculate the total area of forest in a land cover raster.
import arcpy
# Specify the input raster
in_raster = arcpy.Raster("landcover.tif")
# Create a PixelBlockCollection
blockCollection = arcpy.ia.PixelBlockCollection(
    in_raster, pixel_block_size = (512, 512), nodata_to_values = -1)
forest_cell_count = 0
# Iterate through each PixelBlock
try:
    while True:
        pixelblock = next(blockCollection)
        np_array = pixelblock.getData()
        forest_cell_count += np.count_nonzero(np_array == 1) # value = 1 is forest class
except StopIteration:
    pass
print("total forest pixels : " + str(forest_cell_count))
