What is the Knowledge Graph module
The arcpy.kg module is a module for working with knowledge graphs. Use the module to connect to knowledge graphs, inspect data models, perform openCypher queries, perform full-text searches, and work with entities, relationships, properties, domains, identifiers, and other data model components.
A knowledge graph stores information as entities, relationships, and properties that describe real-world objects and the connections between them. The module provides access to both graph content and graph schema information.
Knowledge Graph components
Component Description
Classes Knowledge Graph classes are used to connect to knowledge graphs, access the data model, and perform queries and searches.
Related topics
